Afternoon all ,Given like some of you ,my car only goes out at the weekends ,March to October ,which is the best battery for the job?
I still have the "tab" type leads ,Would appreciate a battery make and number
Cheersfnow Nick M
Best Battery
- Car(s): 1984 2.8i ,daily driver ,stratos silver
Re: Best Battery
Ni Nick,
The 097 battery is standard for the 2.8, and should be man enough for the job.
They're still easy to obtain with flat terminals too.
http://www.ebay.co.uk/itm/Pline-097-12V ... XQH-pRCQsy
http://www.ebay.co.uk/itm/097-Numax-Pre ... xyOMdS-LQ7
I haven't bought any of those brands as a car battery, so I won't comment on which is the best for the Capri. However, I did buy a Powerline battery for the lawnmower and it's still going strong 4 years later.
All the best,
All the best,
Re: Best Battery
Thanks Andrew Iguess theyre all much the same unless you want to fork out big bucks,Mine suffer through lack of use.The one that's on has just started playing up after 3 +1/2 yrs
Re: Best Battery
Just disconnect the negative battery terminal when not in use, and it will fire up fine the next time you use itnickmatteri wrote:Thanks Andrew Iguess theyre all much the same unless you want to fork out big bucks,Mine suffer through lack of use.The one that's on has just started playing up after 3 +1/2 yrs
Re: Best Battery
Also, bring the battery into the warm over the winter, if you don't have a heated garage.andyd wrote:Just disconnect the negative battery terminal when not in use, and it will fire up fine the next time you use it
