Internal Fuel Pump modification
cabaret
Car(s): Ford Capri 2.0i
Skoda Fabia 1.9 SDI
Post by cabaret »
So stupidly i spld my 2.8 tank.....
And personally I thought the external fuel pump was a bad idea cuz they get dirty and corode, all cars nowerdays have internal fuel pumps, some in a little plastic cassette which is basically a combined swirl pot
Fuel sender
Swirl pot
And fuel pump in one.
Am I correct in saying i can use one off a mondeo or a focus? I will adapt the tank myself
I am the Nightrider. I'm a fuel injected suicide machine. I am the chosen one The mighty hand of vengeance sent down to strike the unroadworthy! Im hotter than a rollin dice. Step right up, chum and watch the kid lay down the rubber road, ride to freedom!
340truck
Car(s): Rat - GONE
Re: Internal Fuel Pump modification
Post by 340truck »
Get the wiring right.......one itsy bitsy spark and......kaboom.
cabaret
Skoda Fabia 1.9 SDI
Post by cabaret »
So what you've just said applies to every single car on the road made after 1996, some even before that. How many of them have gone kaboom? The top of these fuel pump have just 2 connections surely cannot be that hard?
You need oxygen for a spark
And It's the vapour that burns. If you could find a way to put a match straight into petrol without encountering any fumes on the way it would simply go out.
If everything is totally immersed in fuel you will be fine.
But still 'get the wiring right'. No point in tempting fate.
Even the external fuel pumps are basically running an electric motor inside a casing full of fuel.
nigecapri
Post by nigecapri »
Cut as big an area of tank base around the pump as you can otherwise you risk melting the swirl pot during welding.
You'll also need to consider cleaning the internal weld as much as possible to reduce chances of slag remaining. Best for flushing/washing out is a bottle of white-spirits, cheap as chips, will not be a problem if any remains (will evaporate anyway) and won't readily ignite - I tested it. Also it's good for checking soundness of a weld for leakage, water isn't any good.
And - when the guy at the scrappy says "It's empty mate, we drain them all when they come in" Don't believe a word of it whilst you're under there with a hammer & sharp chisel.
rshyndy
Car(s): Ford Escort XR3i MK5a, Lexus is200se
Ford Capri 2.0 laser MK3 resto project
Post by rshyndy »
Capris have sender units mounted to the side of the tank but most newer cars have sender/pump/swirl pot mounted on the top of the tanks usually accessed below the rear seat bench. So I think using a newer pump as a sender aswel would not work because it would be in the wrong position.
Or am I getting mixed up here???
I KNOW MY CAR IS OLDER THAN ME......WHATS YOUR POINT???
If it was in the correct tank it would `work` but it wouldn`t be calibrated for the capri`s gauge so the readings would be wrong.
nigecapri
Post by nigecapri »
Existing sender just stays in the original tank - no problems. It's just the pump & pot required for such a job. A Pro-welder would be useful.
