Hallo,
i'm trying to reinstall the horn on my Capri MKII. (it never worked)
I have 1 wire next to the light, who gives 12v. So that's okay.
But, this horn has 2 connections (one marked "G" the other Side "8F")
When I connect them both to the battery, I get a signal for about 0,5 seconds and lot's of sparks.
When I connect only 1 of the 2 to the battery and use the 'ground' of the car, nothing happens.
What is the correct way to connect this thing? From what I see on the forum, the std horn only has 1 connection en ground trough the mounting bolt?
MK2 horn question
- Car(s): crapper
Re: MK2 horn question
have you checked its a 12v horn? that to me looks a lot like the old military 24v horns I had that do exactly the same thing you say yours does
It's a 12v
It says 'klaxon kw9' on the back.
usually these horns have a screw on the back which you can fiddle with to change the pitch a bit , if you fiddle it to far in either direction the horn no go . I would think that the earth wire would be connected to the mounting bolt , that's if the + feed is switched ( horn button ) , sometimes the power + is permanently on and the earth is switched by the horn button . Some cars have a permanent + feed to all gadgets and the earths are switched , called " earth return switching " and I just cant remember what the Capri has , either way connecting both wires straight to the battery as described should produce a continuous ( deafening ) sound ......... maybe if you connect her all up and fiddle with the screw ...............set of air horns cost bugger all , I had 3 sets on mine but was refused a warrant of fitness ( 6 monthly check .... like an MOT ) coz it was way to loud had a few laughs tho , made some chick drop all her groceries , then she got all potty mouthed ........ which only made it better
- Car(s): Capri 2.8 injection special (restoration) Isuzi D-Max pickup (daily driver) Hyundai Santa fe (for towing)
i would agree.
Best test is to connect a pos lead and neg lead to the horn, try either way around if your not sure as you can't damage it due to reverse polarity. If its good you will get a constant sound. if not replace with new as they are as cheap as chips for a pair of different tone horns, thats what i ended up doing.
good luck
Mart
good luck
Mart
Hey, good advice, thank you very much!
