Hi All
I am due to change my front bilstein inserts (2.8i) following deliberation whether to swap from original 2.8i legs to converted coil overs complete with new gas inserts etc. - Has anybody completed this task with any info greatly appreciated.
cheers
Mart
Bilstein front suspension leg insert replacement
- Will01
Alfa 156 GTA (Daily Driver)
Alfa 2.4JTD Sportwagon
Mini Cooper S (Wife's)
Re: Bilstein front suspension leg insert replacement
Better to convert non billies (e.g. 1.6 or 2.0 struts) as you will have more options for inserts.
This is what i am doing currently and keeping my billies for more of a standard replacement if ever needed
- Car(s): Capri 2.8 injection special (restoration) Isuzi D-Max pickup (daily driver) Hyundai Santa fe (for towing)
Will01
Thanks for your reply, interesting theory but i thought the 2.8 legs were slightly different than the 1.6 & 2.0 versions due to power and engine weight, not sure of exact differences though, plus i would prefer to keep original legs if possible?
cheers
Mart
cheers
Mart
- MattMe
- Car(s): Mk3 2.8 injection
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
I spoke to Martin (Capri Gear) about this once and he mentioned you can actually send your original inserts off to Bilstein to be reconditioned at a reasonable rate (similar price to buying new inserts).
If you want originality that's got to be the best option.
Cheers,
Matt
Cheers,
Matt
- Will01
2.8 legs have bilstein inserts which are bolted at the bottom. You can get them reconditioned to keep.standard or if converting to coilover there are only a couple choices for new different inserts.
If you take 1.6 or 2.0 legs you can convert to coil over with threaded sleeve which is same for both type of leg.
However due to internal dimensions there are a lot more options for inserts.
I have a set of billies which I bought to convert. But after a lot of research I have decided to keep in std condition as they will also keep their value. I had a very rusty crappie looking set of 2.0 legs which I sandblasted and they have turned out to be in.perfect condition for.coil over conversion.
Thanks for your replies gents.
I think that i will pursue the Bilstein refurb route. I have been provided with a link from Andrew of which led me to a website called Gartrac. They have all the parts required to carry the full refurb so i will give it a go.
thanks again.
Mart
thanks again.
Mart
