Rear diff leak
Rear diff leak
I have a leak from my diff at the bottom of the diff plate and I am constantly having to torque up the bottom bolt in order to stop it leaking. For some reason it keeps coming loose? This is the bolt with the ratio tag, I was thinking of taking it off and/or putting a spring washer between the bolt and the diff plate? Is this a bad or good idea? Could it be the ratio tag shaking the bolt loose? Thanks in advance guys!
- Ghia15
Re: Rear diff leak
If the leak is being caused by the bolt working loose then that is not a big problem.
Might be worth checking the diff cover for holes and changing the gasket while you are at it, This has the added benefit of ensuring most of the oil in the diff is fresh.
I would then use a low strength thread lock on the bolts to hold them in place nice and tight and ensure they are torqued up to the correct load.
You could also put a spring washer on as well, a sort of belt and braces approach.
Hope you get it sorted bud.
Re: Rear diff leak
I agree, spring washers should reduce the likelihood of the bolts working loose.
Re: Rear diff leak
Have you torqued the bolts or just nipped them up? Reason I ask is it could be simple back off due to low clamping force. At the other end of the scale the bolt could be yielding due to excessive force!
If the gasket has deteriorated then excessive tightening will distort the cover & force the gasket out.
The covers do corrode through - it's not that obvious in all cases & if the hole is above the natural oil level then it will only leak at speed & be more obvious when hot as the oil is thinner.
For price of a gasket & some hypos it's worth pulling the cover off, clean it down & check for pin holes. If it's ok paint it & refit. If not then it'll be a replacement cover.
When you refit a dab of thread lock will ensure it's not a problem in the future.
Had to do mine as it had rotted through - very straightforward if smelly job....I hate the smell of hypoid!
Stew.
Stew.
Re: Rear diff leak
Cover is brand new and gave it a thick coat of hammerite before it was put on, it literally seems to just be this one bolt which the ID tag (the tag does dig into to the bulge on the cover abit) is on that works its way loose slightly. The others haven't really come loose. Torqued the bolts to 45 Nm.
- Ghia15
Re: Rear diff leak
Sounds like a simple fix then.
Get a spring washer as you suggested and a dab of low-medium strength threadlock. Make sure it is not the permanent stuff as if you ever need to remove the cover it will be a pain of a job. Speaking from experience there.
Usually use a stick of locktite from halfords or a bottle of the same, but in liquid form, from my bolts supplier.
Re: Rear diff leak
The loctite used to come in different colours; red for just sealing joints but minimal fastening strength,; blue for standard locking where disassembly may be required; green for `permanent` - or at least very strong fixing.Ghia15 wrote: Make sure it is not the permanent stuff as if you ever need to remove the cover it will be a pain of a job. Speaking from experience there.
Re: Rear diff leak
And isn't it common practice to leave a coloured mark on the bolts which have been secured with loctite?
Re: Rear diff leak
That would make sense, can`t say I`ve experienced that, but then I have nothing to do with garages so may well be the case Then again, nowadays would you expect a job to be done to that standard, lucky if bolts are not sheared off or missing?
Re: Rear diff leak
I only said that as some bolts (diff to propshaft for example) have blue marks on my car.
Re: Rear diff leak
Ah, I think that`s Ford-ese to tell you that they are higher tensile (10.9) than standard bolts. I think, coiuld be wrong?
Re: Rear diff leak
Weren't the propshaft to differential flange bolts coloured blue originally? As Steve says, to signify that they were higher tensile bolts.
There's a set on Ebay for sale for £14.
Re: Rear diff leak
I don't think they are coloured blue, but looks to me like they have been marked that way, as in a brush stroke of blue paint. However, from what you guys have said I need to take another look.
Re: Rear diff leak
http://www.ebay.co.uk/itm/Ford-Capri-MK ... -4pTDlreXwpbar wrote:I don't think they are coloured blue, but looks to me like they have been marked that way, as in a brush stroke of blue paint. However, from what you guys have said I need to take another look.
Re: Rear diff leak
Mine certainly don't look like that (if memory serves) but appear to have a dash of blue. Unless the colour has worn away, will be down on my knees tomorrow hopefully!
Re: Rear diff leak
Yes, they`re only painted with a sort of matt blue, it will have rubbed off probably.
Re: Rear diff leak
Having had another look I think you're right, just rubbed off leaving a few dabs of blue behind. Thanks to you both. You live and learn, I'm glad I mentioned it now.
