24v Electrics
- Car(s): Freshly painted 280 shell.
24v Electrics
Still going crazy over not being able to sort my electrics out. So I have my battery in the boot and the large power cable going from the positive terminal to the starter motor, however, should there be a wire connecting the starter to the alternator?
Re: 24v Electrics
You need to re-connect the little black wire which used to go to the Batt +ive; that supplies all the electrics in the car, bar the starter. You can connect it to the Heavy +ive at the starter as it serves the same purpose, all connects to the battery. Other than that all the wiring will be as before (including the ballast bypass lead from the solenoid on the starter
Hang on ---- What do you mean by 24v electrics? You`ve surely not got a 24v battery or something???
Re: 24v Electrics
I think he means 24 valve
Since I got a capri I've said "over the moon" a lot more than ever before.
Re: 24v Electrics
Sorry - I just thought ....... Especially `Burnt Capri`.....
Re: 24v Electrics
lol. No, indeed it is a 24v cosworth capri. And the burnt part is in reference this, after having a stainless exhaust fitted to my 2.8i turbo
which led to me buying this headache, many many moons ago......
which looks like this now
back to the original post, the car was a bare shell when purchased so knowing what the wiring looked like prior is a problem. However, I had a 2.8i loom adapted by Caprisport and am still more than lost. This has been the biggest headache to date with the car. I just have two bundles of wires and a collection of relays he made up for the inside of the vehicle.
- Car(s): mk1 1.6 capri(restoration.mod)..jaguar s.type every day driver.
land rover discovery es v8 .my wifes. audi v6 cabriolet ..
Re: 24v Electrics
Hi nice car .have you manged to sort your wiring issue .only asking as i have the ford wiring diagram for the 24v cosworth .as im transplanting the boa engine into my mk1 capri widearch ....may be able to help you out
Re: 24v Electrics
I have a colleague who is a whizz with these things. He's done the wiring in all the BOA and BOB conversions that I've been involved in.
