Hi guys I'm in the middle of restoring my Capri
I was cutting out the rear lower corner as it had some bad rust starting however when I pulled it off
I came across this foam stuff between the panel undernieth and the top panel just wanted to know if this was normal or Mabey a bad bodge ?
mystery foam
- Car(s): Ford Capri 1.6 laser (restoration project)
mystery foam
Restoration progress http://s1368.photobucket.com/user/hharv ... %20project
Re: mystery foam
yep, it tried to catch fire on mine when I had the same place repaired.
Since I got a capri I've said "over the moon" a lot more than ever before.
Re: mystery foam
That happened to me and iv removed some does that matter or
do I have to buy some of the foam?
- nigecapri
Re: mystery foam
It's soundproofing to reduce road noise from the tyres. It also causes that rust you have due to water seeping between the foam & panelwork. Get rid of as much as you can.
Re: mystery foam
On it cheers!
- Car(s): 2.8 (resoration)
MX5
2 Escort estates (oilburners) ONE CUT UP OTHER WAITING FOR SCRAPPING
VOLVO V70
MONDEO ESTATE WORK CAR - Location: France, Charante Maritime
Re: mystery foam
It is self extinguishing, but would still remove what you can. and if welding have an extinguisher to hand.
- Car(s): Ford Capri 2.0 laser (finally back on the road). Ford Focus 1.8 Zetec (daily driver)
Re: mystery foam
Mine caught fire when I was welding.
Re: mystery foam
Exactly the same happened to me!
