dim headlights through puddles
- Car(s): crapper
Does anyone else get dim headlights when driving through puddles?
I know its the alternator getting wet but surely it shouldnt be able to get wet enough during some splash back?
At the very least not to clean konk out for 5 seconds then come back to life. Does anyone else get this mad issue?
Thinking of making a small shield up for it or something.
Re: dim headlights through puddles
Not the alternator, even without the alternator the lights should continue to run off the battery. The fault must be to do with the light circuit.
...unless the battery is weak too maybe then?
Blimey, how deep are these puddles that you're driving through?vp-reynolds4 wrote:Does anyone else get dim headlights when driving through puddles?
yeah , that's what I was thinking toopeers.dupp wrote:Blimey, how deep are these puddles that you're driving through?vp-reynolds4 wrote:Does anyone else get dim headlights when driving through puddles?
- Car(s): crapper
Should have elaborated. Its not much of a dim. If you switch on full beam and let the car idle (at least on mine) the headlights get just a touch brighter with a small tap on the accelerator. It only goes a tiny touch dim hitting the puddles.
Believe me they catch you out. On my back road they can hit spray lorry high only at 30 mph.
- nigecapri
They're 12 volt bulbs and will glow off the battery but the alternator will give a bit higher volts so they'll glow a bit more around tickover then glow a bit more at higher revs when the alternator gives full output. With the draw of the headlights on the system plus probably blower & wipers there will be more load on the alternator making the belt more likely to slip when it gets wet.
Check the belt tension - 1/2" on the longest run is fine.
Get yourself a multi-meter & check battery volts not running then battery volts at revs. Not long till cold nights and better to find out you have a duff battery now than when you need it one frosty morning.
- Car(s): crapper
I know for a fact the battery is in top shape. I recently bought a new one and it supplies that mad speaker I have in the back no problem with the engine off. I know its the alternator. Is that maybe a sign of wornoutedness?
You started this thread 4 days ago ..... have you not checked the fan belt yet ?????
You could , if you were really keen (anal ) hook up a volt meter to the ciggy lighter and go look for a puddle ( bet it doesn't rain for weeks ) and see if there is an actual drop in voltage , and after you've arsed about doing that just go tighten the fan belt
4 days .... bugger me !
What in Northern Scotland?Mc Tool wrote: ( bet it doesn't rain for weeks )
(Posted in error)
- Car(s): crapper
Id rather not “bugger” you but your right it doesn't rain for weeks up here. The climate is very off at the moment. Now I have checked the belt as I always do on my monthly anal check over of everything on my car. Read what I put to discover I'm telling you it’s the alternator itself. I only asked if anyone else had the same issue or is mine for the knacker’s yard.Mc Tool wrote:You started this thread 4 days ago ..... have you not checked the fan belt yet ?????
Just seen this thread -
Would also be worth checking all earths - particularly the ones in the headlamp bowls - have caused me some grief in the past - especially considering problem involves water/puddles and they back onto the wheelarch.
.vp-reynolds4 wrote:Id rather not “bugger” you but your right it doesn't rain for weeks up here. The climate is very off at the moment. Now I have checked the belt as I always do on my monthly anal check over of everything on my car. Read what I put to discover I'm telling you it’s the alternator itself. I only asked if anyone else had the same issue or is mine for the knacker’s yard.Mc Tool wrote:You started this thread 4 days ago ..... have you not checked the fan belt yet ?????
Some smilies would have been nice .... Anyhow seeing as how the capri alt output does not go straight to the battery but is wired to the "ign on " side of the circuit disconnecting the alt is probly not a good idea ( the theory being that with the alt disconnected the lights should be dim all the time , not just when wet ) . This MAY prove the alt to be faulty .I cant recall the last time I found a fault that increased resistance when wet ( thus lowering voltage output ) so , If it is the alt I would say we are looking for a partial short circuit that is worse when wet. This sort of short should be visible as carbon tracking , or some other sign of heat or sparks , maybe melted brush holders, so if you take the cover off the alt , blow all the dust and shit out and have a butchers..... there should be something to see. Try the meter in the ciggy lighter , it would be helpful to know if its just the head lights that dim or everything in the car..... maybe switch the fan on to full speed and see if you can hear the fan slow down with the lights .... actually the more things you turn on ( rear window heater ) the more obvious the fault should be
- Car(s): crapper
I know the voltage is good. It measures a strong 13.6v dc and only drops to 12.7 vdc with a 52 amp load from a giant speaker. When i dissconnect the alternator it reads 11.9vdc and drops to 10.9 with the crazy subwoofer pounding death. When i hit the puddles it drops out completley as if the alternator dissconnected itself and 5 seconds later comes back strong. The laternator does get wet through a puddle but not terribly. No damage or shorting has been going on. brushes check out and so does the voltage regulator. It has no bad bearings but occasionally makes a continuous noise like somebody sweeping a floor on cold starts. I know it charges the battery sweet because it handles the subwoofer constantly which otherwise goes flat in a timed 34 minutes without. I really would love a new 75 amp alternator.
I have another theory....................
When you use the wipers to clear the spray off the windscreen, do the lights look brighter again
- Car(s): crapper
nope nothing electrical changes the output of the headlights only puddles lol
I had the same problem with my old 2.0s! It took me ages to work it out, every time I went through a puddle the water put the candles out!!
- Car(s): crapper
Now thats funny!NeilL wrote:I had the same problem with my old 2.0s! It took me ages to work it out, every time I went through a puddle the water put the candles out!!
Ha ha ha my 1st thoughtBug wrote:I have another theory....................
