dash lights
spud20s
Car(s): 84 ford capri 2.0 s (daily)
dash lights
Postby spud20s » Sat Jun 14, 2014 3:59 pm
hi was wondering if anyone knows of there is a relay or something that controls all the dash lights. everything is dead, instrument panel, heater panel, cig lighter, clock and glove box light. the lights work outside when switched but nothing whatsoever inside. ive not really got any idea where to start looking. help anyone? thanks.
Re: dash lights
Postby Andrew 2.8i » Sat Jun 14, 2014 4:17 pm
Do the horn and hazards work? If not, it's probably the no.1 fuse (16 amp).
spud20s
Re: dash lights
Postby spud20s » Sat Jun 14, 2014 4:31 pm
yeah they work. checked fuses. that was the first thing I went for but everything else on the car seems to work. I don't really want to rip the dash out a check all the wiring. not that theres much lol
Re: dash lights
Postby Caprigear » Sat Jun 14, 2014 5:37 pm
Try turning the dimmer switch fully to the left and then back to the right several times. I've known that to work sometimes.
Re: dash lights
Postby Mc Tool » Sat Jun 14, 2014 9:37 pm
My next guess would be the light switch on the steering stem , or the plug .If your #uckin good :xd: you can get them apart for a clean up . I used blobs of 5 min araldite to hold it back together , and there have been some on.............ah I mean Caprigear is sure to have a good spare :) . Have a butchers at the wiring diagram.......there is some weird shit going on there , looks like it was designed by monkeys
spud20s
Re: dash lights
Postby spud20s » Sat Jun 14, 2014 9:58 pm
hi thanks for the replies. the dimmer is out of the equation because I've joined the wires straight together because I have LED instrument lights. looking at the back of the instrument cluster I found the wire that supplies power to the bulbs and then found the same wire on the switch which is putting out power when you turn on the side lights. I've basically worked out there must be a break in the circuit between the back of the switch and the point where the power must be distributed to all the lights. I've put in a wire from the back of the switch and joined it to the live for the cig lighter bulb and wehey we have dash lights. so not exactly sure where the problem is and how it happened but I've cured it. probably not the right way though.
Re: dash lights
Postby Andrew 2.8i » Sat Jun 14, 2014 10:51 pm
There are some good simplified circuit diagrams on this site:
http://ccscotland.fr.yuku.com/topic/151 ... 5zOrGdOU5s
Might help you to trace where the fault in the original wiring is.:goodluck:
Re: dash lights
Postby stevemarl » Sat Jun 14, 2014 11:08 pm
spud20s wrote: I have LED instrument lights. l
You do know they`re polarised & will only work one way round?
Re: dash lights
Postby Bug » Sun Jun 15, 2014 8:40 am
So! After several replies, have we now finally established that it was you doing something to it that stopped it working?
In that case, there's a fair chance you've caused it.
So step one is to go backwards through what you've changed until you find the answer.
Initially I'd try just unplugging and reseating the plug in the back of the instruments. Could just be a dodgy connection
Re: dash lights
Postby Mc Tool » Mon Jun 16, 2014 12:14 am
If the glove box and heater lights also don't go then the fault is common to the dash AND other interior lights .... so not the plug in the back of the dash . By providing a power supply to the ciggy lighter you are now feeding power into that circuit at the middle or even the end , which is OK electrically , but is really hiding the real fault . I would get it sorted , I still suspect the light switch and if its falling apart it may well deteriorate further and possibly leave you without any lights ( at the worst possible time :) ) , and just in case you think your loosing the plot ..... the 2 tail lights DO run off different circuts with different fuses. When my switch packed it in I lost only 1 tail light , and not being used to pommy wiring , plus a bit of tunnel vision ..... I was there for a while :swear:
Hamish
spud20s
Re: dash lights
Postby spud20s » Fri Aug 22, 2014 5:53 am
thanks for the replies. the lights still turn on with the normal switch so I know it cant be that. it works now so I'm not going to mess with it trying to find the original problem. before I was replacing the led's every few months because they started flashing but now I've not had a problem at all. it's all coming out soon anyway, it's going zetec and I need to hide the wiring behind the dash. thanks guys.
chris_v888
Car(s): pontiac formula 400 (restoration project)
Re: dash lights
Postby chris_v888 » Wed Nov 28, 2018 4:43 pm
hi there I have this same problams with my mk3 I've got the dash all out to fit a new alarm as a serton wife left with the keys lol so whilst I was doing this I noticed some winer's and that where cut as I forgot to lable them I wondered if anyone can tell me where Thayer go think Thayer are to do with dimer switch? gray x3 and 2 gray and yellow any help would help as it dose not look good with no dash in car driving around lol thank you and sorry for jumping on someone else's thred?
Re: dash lights
Postby Andrew 2.8i » Wed Nov 28, 2018 5:33 pm
chris_v888 wrote:Thayer are to do with dimer switch? gray x3 and 2 gray and yellow any help would help
Hi Chris,
The grey wires are the feed from fuse 2.
One grey wire goes to the heater illumination.
One grey wire goes to the cigar lighter illumination.
One grey wire goes to the dimmer.
There are two grey/yellow wires off the dimmer.
One goes to the dashboard clocks illumination.
One goes to the centre consol clock illumination.
I hope that helps.
chris_v888
Re: dash lights
Postby chris_v888 » Wed Nov 28, 2018 6:40 pm
right after gray wiers x2 become live when you turn lights on gray and yellow comes from the right hand side as you look at it along with the 2 gray ones I and the other gray and wellow wiers comes from left hand side of dash heater light looks all intackt thanks again for all help
chris_v888
Re: dash lights
Postby chris_v888 » Wed Nov 28, 2018 11:21 pm
well got the lights working now no rev counter fule Gage or temp gauge what have I done as Thayer where all working befor???? :banghead: :banghead:
Re: dash lights
Postby pbar » Thu Nov 29, 2018 7:12 am
chris_v888 wrote:well got the lights working now no rev counter fule Gage or temp gauge what have I done as Thayer where all working befor???? :banghead: :banghead:
Sounds like the voltage regulator at the back of the clocks has gone.
Here is your info for that -
http://www.capriclub2000.co.uk/help-inf ... mp-gauges/
If you do not have a riveter, you can use a small nut and bolt to fix it in place.
Re: dash lights
Postby Andrew 2.8i » Thu Nov 29, 2018 8:31 am
Hold your horses!
Before you change the voltage regulator, it sounds like fuse 7 might have blown. Check that first, but if that's OK there could be a fault with the black/yellow wire from fuse 7.
This also feeds the ignition warning lamp and the handbrake warning lamp, so if they are also not working, that is almost certainly the cause.
chris_v888
Re: dash lights
Postby chris_v888 » Thu Nov 29, 2018 8:56 am
thanks for the quick replys will look at them when I get in thanks all
Re: dash lights
Postby pbar » Thu Nov 29, 2018 9:45 am
No problem Chris, and good luck!
chris_v888
Re: dash lights
Postby chris_v888 » Thu Nov 29, 2018 10:47 pm
thanks guys for all your help I think it was something I done with a soldered wider and and burnt 2 tracks out rerun 2 new wiers put it back in car and all working thank you all for your help
