What do I need?
What do I need?
Hi all
What do I need to make a non standard steering wheel fit my mk3 capri?
Saw a nice wood one today at the show which I wanted but didn't no if it would fit as the hole in the centre looked rather large.
Re: What do I need?
A welder. Ingenuity. Top boss.
Re: What do I need?
You need a boss to fit the Ford splines which the steering wheel will bolt to. In my opinion, why bother when there are so many Ford wheels to choose from that will fit straight on?
Andrew
Andrew
Re: What do I need?
I like to be different mate. I like the capri wheels but everyone has them. I want a unique carpeers.dupp wrote:Hi,
Andrew
Re: What do I need?
Hi,80s kid wrote:I like to be different mate
I would never have guessed!
Before you buy any aftermarket steering wheel, make sure you factor in the cost and availability of a boss as well.
Re: What do I need?
I don't no anything about a boss mate, I assume that's what keeps it on the steering colum? Would I need to get a different one depending on what steering wheel I buy?peers.dupp wrote:Hi,80s kid wrote:I like to be different mate
This one had a big hole in the middle, miles bigger than the wheel on the capri now.
Re: What do I need?
It`s just a sort of adaptor, it`ll fit on the column & have the correct pattern of bolt holes for the new wheel
Re: What do I need?
If you just have the wheel how do you find the right boss?stevemarl wrote:It`s just a sort of adaptor, it`ll fit on the column & have the correct pattern of bolt holes for the new wheel
Re: What do I need?
Ebay?? Do you know the maker? Otherwise you`d need to measure the diameter of the hole spacing and ask a seller.
Re: What do I need?
Ok mate cheers. I have ordered one that had come off a capri. If it don't fit on what's already in my capri ill find a boss that does. The hole looks quite small tho like the one on my capri atm so you never no I may have some good luck and it just goes to plan... Yeah rightstevemarl wrote:Ebay?? Do you know the maker? Otherwise you`d need to measure the diameter of the hole spacing and ask a seller.
Re: What do I need?
"capri boss" on ebay - it will have one of a couple of different fitments though, so hopefully it will say the type on it - usually they say what brand they're for, e.g. "Mountney" "momo" mota lita" "springalex" etc. Ignore the people saying "why bother" it's your car, do what you want! One of the first things I did was ditch the fugly grey plastic 80s steering wheel.
Re: What do I need?
Why not just leave the original Capri wheel on, and have no problems80s kid wrote:
Re: What do I need?
Hahapbar wrote:Why not just leave the original Capri wheel on, and have no problems80s kid wrote:
Its looking very tatty and im trying to make my capri unique. Ill try and find someone to recondition the old steering wheel if i can.
Re: What do I need?
i agree with JC its your car do what you want to it
- Car(s): Ford Capri X-Pack 1987
Re: What do I need?
Definitely do what you want to do with it. I used to have the mountney steering wheel which i really liked the look of. A lot nicer than the standard wheel and went lovely with the stainless steel dash inert in my opinion.
Re: What do I need?
Failing that, why not keep a lookout for a good condition original one. They are sought after, look great and will give a lot of appreciation from all quarters, much more than you would earn with any aftermarket contraption.80s kid wrote:Ill try and find someone to recondition the old steering wheel if i can.
- Toecutter
- Car(s): 1973 Mk1 (Facelift) Capri - 2.0 Pinto on Bike carbs
Re: What do I need?
Have to agree, the old Mountney Wheels are very nice, I have one with alloy boss fitted in my Mk1, the original Ford RS steering wheels are very nice too but go for pretty big money.SpikeCapri wrote:Definitely do what you want to do with it. I used to have the mountney steering wheel which i really liked the look of. A lot nicer than the standard wheel and went lovely with the stainless steel dash inert in my opinion.
Scout ebay for one but I think you should get one that is ready to bolt on and save yourself some grief faffing about with bosses that may or may not fit right.
Re: What do I need?
Search for older muscle car wheels on ebay states site. I found this for 45usd shipped.
Had to buy the boss kit and the horn mechanism seperately but I don't remember the cost of it. Not a lot though. The steering wheel was made by Grant and I tracked down the boss kit based on that. ("Grant challenger steering wheel adapter")
Re: What do I need?
Escort mk2 boos should fit fine then just choose the bolt fitment for the steering wheel
