Hello all,
My capper is getting hot, top of the Rad and expansion bottle are hot and pipes feel under pressure. Bottom of rad pipe cold
When I had a look in the part where the sender goes (white ring) there was no coolant.
The engine was rebuilt last year due to the head going and at the same time I had the water pump replaced and the radiator re-cored, the caps are new and the right way round, the thermostat is the correct one.
I'm getting at the end of my tether with her lol I need some help
2.8 cooling woes
- Car(s): ford capri 2.8 i
- Car(s): Capri 280 Brooklands, (Summer months only)
Nissan Qashqai (Company Car) - Location: Selkirk, Scotland
Re: 2.8 cooling woes
is the water circulating through the radiator? I know it's been re-cored but it might be worth checking if you have not already.
- Car(s): Rat - GONE
Air lock.....solution is to let it blow! ie let it get hot and then take expansion cap off, have a cloth around your hand! It'll blow everything out like a whale, then refill it - airlock gone.
ok will trickle some coolant in to the highest hose to eliminate that gap then try the heating rag method on Saturday and report back ta
That or your thermostat is stuck shut.
