type 9 gear oil change?
spud20s
Car(s): 84 ford capri 2.0 s (daily)
Post by spud20s »
hi. anyone know how to drain a type 9 box. can't see a drain plug at all. I was thinking of take the speedo out and try drain from there? or is there somewhere else to do it?
thanks spud20s.
Re: type 9 gear oil change?
Post by Caprigear »
There isn't a drain plug. Easiest way to get the oil out is to get it sucked out by a vacuum pump.
r2vdh
Post by r2vdh »
or pull the prop out and allow most of it to drain..... then just refill :beer:
Sonic
Car(s): 2.8 efi Special
1.6 LS
Post by Sonic »
I've done the prop out method multiple times. An awful lot of unbolting to do though.
I had the front up on ramps to gain access and also it allowed it to drain. I left it over night and came out to find my tub full of water with a skim of oil. Type 9's let water in apparently.
Best of luck.
Ghia15
Post by Ghia15 »
Either method is good.
Got a hand operated vacuum from tool station for about £20, does the job and is simple to use and saves alot of unbolting.
Also used it to empty the brake fluid when changing the MC and can be used for the Diff.
Post by stevemarl »
:agree: Easiest (& cleanest!!) by far. Got same thing from ebay, really useful.
spud20s
Post by spud20s »
cheers for your replies everyone. think I'l try the vac idea. the prop is a pain to drop.
