Auto-choke or not to auto-choke
Stonebumble
Car(s): Ford Capri 3.0s
Postby Stonebumble » Fri Jan 04, 2013 4:20 pm
Hello everybody,
The auto-choke on my 3.0s doesn't work, so I found a manual choke cable to convert it. Is this an easy job or more importantly, is it a good idea to convert an automatic choke to a manual?
Thanks and Happy New Year!
jerome-v6
Car(s): ford capri 3.0s
Re: Auto-choke or not to auto-choke
Postby jerome-v6 » Fri Jan 04, 2013 4:43 pm
I've got a 40DFAV on my essex v6 at the moment and i switched from an auto choke to a manual. On the coldest day of the year your waiting for the coolant to get up to temp to pass through the water housing body on the side of your carb but with an auto choke you can have the butterflies closed straight away, let your engine idle for a few minutes rich fuel/lean air. Then open your butterflies and go. Thats just my opinion, I always start my car and leave it to idle for 5 minutes before leaving my house, I live on a steep hill and don't like to hammer my engine to get up the hill whilst it's cold.
chanley1980
Car(s): 2.9 capri weekend car now with 2.0 lnit
mk4 golf 1.4 16v daily driver
Postby chanley1980 » Fri Jan 04, 2013 6:29 pm
hi mate where did u get the cable my auto choke dont work ether and itsa pain to sit with a few revs on for 10mins for it to warm up and stay running .
Stonebumble
Postby Stonebumble » Fri Jan 04, 2013 6:42 pm
The cable was included in a box of odds, ends and spares when I bought the car. Sorry I can't be more helpful.
chanley1980
Postby chanley1980 » Fri Jan 04, 2013 7:08 pm
ok thanks
nigecapri
Postby nigecapri » Fri Jan 04, 2013 9:03 pm
Does your heater give out plenty of hot air?
If it does then you're getting enough flow through the pipe that supplies the auto-choke to make it work. There's a coiled flat-bar spring inside the domed housing with rubber pipe in/out of it. Normal cold ambient temperature has this spring tuned so that the choke butterfly spindle twists the butterlfies closed. When the coolant gets hot enough, the metal expands - it's fixed at one end so the other end has to twist so turning the spindle it's attached to & the choke opens.
There's not much in there that can break so WD40 and a bit of fiddling should sort it. More info on my workshop page, click photo below:
Stonebumble
Postby Stonebumble » Sat Jan 05, 2013 4:49 pm
Thanks, your workshop page is very detailed. I will have a go at fixing the auto choke rather than converting to a manual straight off.
340truck
Car(s): Rat - GONE
Postby 340truck » Sat Jan 05, 2013 5:14 pm
If you do want to convert to manual choke you'll need more than just a cable - you'll need the complete kit.
Postby Peter-S » Sat Jan 05, 2013 5:26 pm
There's also a rubber diaphragm as part of the auto choke mechanism. Make sure its still intact.
chanley1980
Postby chanley1980 » Sat Jan 05, 2013 7:29 pm
hi can i ask where ur workshop page is plz
Stonebumble
Postby Stonebumble » Sat Jan 05, 2013 9:27 pm
What's in the complete manual choke conversion kit?
You can get to nigecapri's workshop page by clicking the photo in his signature.
Craigorypeck
Chevy Cobalt
Postby Craigorypeck » Sun Jan 06, 2013 3:11 am
:spam:
jimmyted
Car(s): ford capri 1.6L - now 2.0L
Postby jimmyted » Sun Jan 06, 2013 12:17 pm
In classic ford a few months back I’m pretty sure they featured a genuine weber manual choke conversion kit, but I can’t find the issue
I already had the cable installed in the car from the old manual VV carb, and got hold of a 32/36 weber with manual choke conversion already on. Looks like this -
cable coming in from lower right.
Not the most complicated bit of kit, if you fancied having a bash at it yourself.
Postby Major_Tom » Sun Jan 06, 2013 12:41 pm
Go for no choke. Like ironing, you don't really need it.
Stonebumble
Postby Stonebumble » Sun Jan 06, 2013 3:27 pm
That looks nice and neat, if the auto-choke is beyond saving, I will convert! I will also stop ironing.
Return to “Q & A”
Who is online
Users browsing this forum: Bing [Bot] and 5 guests
