Gaz Gold or AVO coilovers? Dipping at SPL ltd?
Gingerfury
Car(s): 1983 2.8i (in bits)
Post by Gingerfury »
Needing help, changing the suspension on the old girl and would like to know what would be the best people to go to. I was thinking about Gaz Gold or AVO coilovers on the front with single leads on the back. Could anyone tell me who makes the better shocks? Also was planning to have the car dipped at SPL ltd. Has anyone gone down this route yet? If so could you pass on your experience and how the car was after?
Tommy
MrCox
Car(s): Ford Focus 1.6 '04 (Daily)
Ford Capri 2.0 '86 (Project/Toy)
Re: Gaz Gold or AVO coilovers? Dipping at SPL ltd?
Post by MrCox »
I couldn't tell you which is better but I currently have AVO Adjustable shock absorbers all round on my Mk3 and am very happy with them. About the acid dipping though there's a thread on another forum about a Capri being dipped at SPL and the pictures don't look good.. rust coming out of the seams everywhere, sediment from the acid dip which hasn't been removed and when it is there's rust underneath... and the customer service doesn't sound that great either!
I've had no direct dealings with SPL and just passing on what I've read..
Gingerfury
What forum is it on? Would like to have a look at it.
Tommy
Swishy
Car(s): 2 X 1.6 LS
Volvo V70 D5 (daily driver)
Post by Swishy »
It's over on Capri Power
Cabbage
Car(s): Capri 280
Modified MX5 2nd Modified Class National Rally 2011
Post by Cabbage »
Gingerfury wrote:What forum is it on? Would like to have a look at it.
Tommy
Here you go Tommy,
http://www.capripower.co.uk/forum/index ... t-process/
capri-deceptacon
Car(s): Ford Capri 2.0 S (1983)
Post by capri-deceptacon »
Im currently running on the GAZ Gold coilovers on the front.
I must say they handle absolutely spot on, never had a problem when things start getting a little serious, even on the track. Yet if you are after a compromise between comfort and performance, do not get them. Any pot hole and speed bump you come across will rattle your teeth out.
Depends on what you intend on using the car for though, like I said though I have never had a problem with them from a performance point of view.
All the best,
Max
