2.8 fuel pump
2.8 fuel pump
I have bought a fuel pump from ebay, only a cheap one to see if its the problem,
anyway is it the wrong one, is there a part missing or do i use something from the old one
thanks
Tony
thanks
Tony
Re: 2.8 fuel pump
thats wrong.
there should be a tube that comes off the tank to the back end of the pump, then end with the connectors on for power has the connector on to send fuel to the fuel accumulator. thats deffo not a 2.8 one.
Re: 2.8 fuel pump
That looks like an 'in-tank' one to me. Definitely not what you want!
Re: 2.8 fuel pump
looks like i ordered the wrong one, though it does state 2.8i
have to go back for refund
anyone recommend where i can get a cheap one?
Re: 2.8 fuel pump
theres a place on ebay does them.
you could get a second hand one from martin at capri gear if its just for ilimination purposes
- Ghia15
Re: 2.8 fuel pump
The original bosch part number for the pump you need is,
0 580 254 910.
This is the one that came with my 2.8i inkection tank.
I have bought a sytec replacement which is the equivilant to the bosch unit.
Not used it yet but it was identical to the bosch pump.
I saw some of the cheap ones and decided against them, the sytec one was half the price of the bosch but have used them in uni and they seem ok.
0 580 254 910.
Re: 2.8 fuel pump
I have just started to get my car back after putting a refreshed 2.8i eng in, been off road for 4 yrs
I put 3 gal in, tried to start no fuel
I bought a new pump fitted works off battery
how much fuel do I need to get fuel to pump?
I have since taken tank off and swirled the fuel round and empty it out, still has a galv coat inside, no sign of silt etc
When I had car up on stands the outlet pipe let out 2/3 of a gallon
So I am guessing I would need 5 gal in at least, or is there a blockage?
- Car(s): "Bertha":- Under reconstruction.
1.6 Laser :- Daily Driver.
Peugeot E7 XS:- Cash box .... Kerrching!!!!!! - Location: Sunny Blackwood
Re: 2.8 fuel pump
have you connected the wires on the pump round the right way ie is the pump trying to suck fuel from the engine back to the tank? Made that mistake myself once.
- nigecapri
Re: 2.8 fuel pump
Tony
Pump is in the van.
I might be with a customer so if you get to Cov then just keep ringing.
Pump is in the van.
Re: 2.8 fuel pump
I have fuel getting to distributor /engine only when I connect a live to the fuel pump
I read there is a regulator if it is it, what dose it look like and where can I get one
James
James
- nigecapri
Re: 2.8 fuel pump
Pink plastic relay above accelerator pedal area / side kick-plate trim.
http://www.capriwiki.com/index.php?titl ... _Suppliers
Re: 2.8 fuel pump
If your old fuel pump relay is dead, I'll happily repair it for the price of a drink.
- T.M.
Re: 2.8 fuel pump
is it possible to change electric connectors from old pump to new one?
There are two long connectors (black and yellow) on old original pump and you only click counterpart connector on it. Like this:
https://i.ebayimg.com/images/g/QU8AAOSw ... -l1600.jpg
But new pump has only thread to fit with O-ring connector with nut. Like this:
https://i.ebayimg.com/images/g/skMAAOSw ... -l1600.jpg
https://i.ebayimg.com/images/g/ibkAAOSw ... -l1600.jpg
https://i.ebayimg.com/images/g/s9IAAOSw ... -l1600.jpg
Tom
Tom
Re: 2.8 fuel pump
I hope somebody can answer your question as I've wondered if that was possible.
- T.M.
Re: 2.8 fuel pump
I hope too! Because I don't want to cut original wires to change conectors.
That original black and yellow connectors look like have some little movement against pump. But I don't try anything to prevent breaking it.
Tom
Tom
