Screws info required
When i eventually put my car back together, i don't want to put the old rusty screws back on and don't want to keep wasting valuable time going to & from B&Q getting screws. Has anyone got the names/sizes of the screws most popular with the Capri that i can just go out and get..ie. Screws for the radiator grill, fuel filter screws, dashboard screws, washer bottle screws...Ta If anoynes got a list...bolts as well would be good if poss.
Re: Screws info required
Have a shufty under 'Capri' on ebay Burt, there's normally quite a few sets of screws and bolts to replace the standard rusty items. A complete set of galvanised bolts for sump, ancilliaries etc for a pinto is around £20 but I'm sure there must be 2.8 sets as well.
Ok will do. Ta
I think I might do this too, since most of mine is also in bits!
- Car(s): capri mk3 3lt ghia(long term project) land rover discovery daily driver 2lt mpi
hi
go on to ebay
look up jez1964
he does loads of stainless nuts,bolts,washers etc............i have had several items from him,his prices are very good.
i got a complete v6 essex bolt set for £40.(water pump,inlet,eng mounts,bellhousing etc).........which inc stainless washers etc. they are good quality.not the cheap shite u can get.
if u do order anything from him can u let him know that xsabbathx sent you....i might get some stuff cheaper then
go on to ebay
look up jez1964
Bigger is better,there is no replacement for displacement
I came across this a while ago and i deal with iron mongery at work so when i was quiet i put my knowledge towards sourcing these screws! To be sad the type you are after are Self tapper recess pan type AB black finish and you'll need to get a few difeerent sizes 10x 1/2" etc
Now thats the info.
Can’t beat a old screw thread from almost 10 years ago .
But yes I finished cleaning and putting back the front today and use all new stainless screws .
Jeepers Jason, you you must have a "screw" loose going back ten years to add to this "thread"....Jasonmarie wrote: ↑Fri Jun 14, 2019 7:29 pm Can’t beat a old screw thread from almost 10 years ago .
Great job you done there mate. Looks very nice indeed
Fordoholic Nick wrote: ↑Sat Jun 15, 2019 1:00 amJeepers Jason, you you must have a "screw" loose going back ten years to add to this "thread"....Jasonmarie wrote: ↑Fri Jun 14, 2019 7:29 pm Can’t beat a old screw thread from almost 10 years ago .
It's all in the details (Apparently)
Thank you kind gents , it’s all the little jobs that make you get closer to a end result what will be another 10 years I guess .
Looking good, Jason. The shiny screws match the other blingy parts you have under the bonnet. Keep up the good work!
I am scared that I am turning in to that yellow Capri with all this bling , just need a big chain around my neck and call me Del Boy
I was even eyeing up Peters fog lamps as they were the real things with a nice silver back plate
W- Mondeo 2.0 Ghia Estate
03 Focus 1.6
It's not just me then! There are a couple of sizes of self tapper which seem to be everywhere - I went down to Orbital and got a bag of 100 off them. Does look that bit better. At least I don't have, err, a screw loose!
Yes I did paint all mine black last year but you can’t beat a shiny screw
