ford capri laser ford capri ford capri laser pinto brooklands injection special turbo tickford service probe Brooklands 280 brooklands 280 2.8 Aston Martin Tickford
Ford Capri Laser Ford Capri Ford Capri Laser Pinto aston martin tickford Turbo Techniques turbo techniques XX pack xx pack RGA rga For Sale for sale Service Guide service guide spares 2.0S 2.0 Laser 1.6 Laser 1.6GL Sport automobile race racing club engine
 Home
 Wiki
 Forum Index
 Rant & Rave
 Q & A
 Parts For Sale
 Cars For Sale
 Members Cars
 Projects
 Gallery
   Register Donate  •   FAQ  •  Search  •  Login
Who is online Users browsing this forum: Google [Bot] and 1 guest
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: I'm sure it's been done but I'm new to this. Re: Timing Belt
PostPosted: Thu Jul 29, 2010 6:27 pm
Offline
Car(s): 1987 Ford Capri Mk 3 Laser 1.6l
I'm just wondering is there a step by step guide on changing the timing belt anywhere on this site? I find the Haynes manual unclear.
Much appreciated,
Chris
_________________
 Profile
 Post subject: Re: I'm sure it's been done but I'm new to this. Re: Timing Belt
PostPosted: Thu Jul 29, 2010 7:31 pm
Offline
Car(s): .
[OO]===o===[OO]
Buy the correct belt- double check it.
Remove the fan belt.
Arrange all of your tools, place the new belt in clean hot water to expand it slightly.
Remove the belt covers. 10mm screws.
Undo the crankshaft pulley bolt.
Pull off the crankshaft sprocket.
Lightly refit the crackshaft bolt.
Cut the belt along it's length- use a Stanley Knife or similar, cut it so the front has two thirds and the back band is only one third of the width of the usual belt. You will need to turn the engine, cut a section, turn the engine, cut a section and so on.
Use the crankshaft bolt to turn the engine. Once you have cut all the way around and have two separate bands, slide off the front two thirds.
DO NOT TURN THE ENGINE!!!
Take the new belt and slide it over the pulleys, sprockets, tensioners etc.
The cam/ crank timing will be left unchanged!!!
Snip the old band and then slide the belt onto the sprockets fully.
Remove the crank bolt, refit the crank bottom pulley.
Tighten the bolt.
Smile!
_________________
Image THE trollkiller. Oh yes! ImageImage NEXT!
 Profile
PostPosted: Thu Jul 29, 2010 8:11 pm
Offline
Car(s): Capri 2.0S '78
Mini Cooper S
Primaster Van
Tighten the bolt.
Smile!
Thats genius! Beats the tipex markings i tried. .
_________________
See more
viewtopic.php?f=16&t=30772
 Profile
PostPosted: Thu Jul 29, 2010 10:23 pm
Offline
Thanks a million. Hope to get this done in the next week or so!
Chris
_________________
 Profile
PostPosted: Fri Jul 30, 2010 7:47 pm
Offline
Car(s): 1981 ford capri 2.0s, used regularly, megane 1.9 dci(wifes) quite enjoyable driving it!!!
Tighten the bolt.
Smile!
so simple, so easy, i :applaud: you sir, just shows you are never too old to learn.
 Profile
PostPosted: Sun Aug 01, 2010 11:25 am
Offline
Car(s): Ford Capri MK3 Carabet
Ford Escort MK2
i done my belt a couple of weeks ago, never tried it before and had never really even see one before,
new blet was £8.
and i managed it and the engine still works :)
its not has hard as people think, just take your time on it.
 Profile
Display posts from previous:  Sort by
Who is online
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
Search for:
Jump to:
