ford capri laser ford capri ford capri laser pinto brooklands injection special turbo tickford service probe Brooklands 280 brooklands 280 2.8 Aston Martin Tickford
Ford Capri Laser Ford Capri Ford Capri Laser Pinto aston martin tickford Turbo Techniques turbo techniques XX pack xx pack RGA rga For Sale for sale Service Guide service guide spares 2.0S 2.0 Laser 1.6 Laser 1.6GL Sport automobile race racing club engine
 Home
 Wiki
 Forum Index
 Rant & Rave
 Q & A
 Parts For Sale
 Cars For Sale
 Members Cars
 Projects
 Gallery
   Register Donate  •   FAQ  •  Search  •  Login
Who is online Users browsing this forum: Google [Bot] and 1 guest
Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: fuelling an EFI
PostPosted: Tue Jul 20, 2010 5:44 pm
Offline
Car(s): project blitz ex 1.6 laser fitting 2.0 uprated suspention with caprisport GTR brakes
OK
Apart from the obvious what fuel line do I need to run under the car to fuel the EFI system
I already have the 2.8I tank that part that prevent fuel lock (forget the name) the bits at the front end for the fuel filter.
however trying to get the two lines for between the front and rear is a nightmare
I have no idea what's legal what sizes pressure E.T.C YET none of the books give this information so I am beyond lost.
So info please will want to get things set-up ASAP.
Oh and I've been in contact with the likes of Caprigear and others, they all tell me they ain't allowed to sell them on.
And you try and find a 2.8I breaking ATM.
The ones near me are owned by people who think a full rotted out wreck is worth over a £K
So info other help etc.
 Profile
 Post subject: Re: fuelling an EFI
PostPosted: Tue Jul 20, 2010 6:52 pm
Offline
1976 Ford/Mercury Capri 2.8 Ghia
1995 Chevrolet G20 5.0 V8 Van
Yo,
I wouldn't bother getting genuine Capri Injection lines. The genuine ones are hard plastic, these days you can get rubber injection fuel hose. The problem with the genuine hard plastic lines is that they are interference fit, which means they push into connectors and generally don't come off again with no need for a jubilee clip. This was fine when they were new, but they have gone hard with age and I found it impossible to get them onto the connectors. So better going for new rubber line.
Most good motorfactors should have a roll of it and you can buy it by the meter. I think when I got some last I went for the 6mm bore stuff. The Capri (Bosch) injection pump runs at about 90psi, most good fuel line will be capable of 150psi. Just make sure you get fuel line that is suitable for these pressures. Fuel line for carbs is only good for about 50psi.
You can even get expensive fuel hose with metal braiding over it to protect it, have a look on ebay, more expensive though.
_________________
 Profile
PostPosted: Wed Jul 21, 2010 3:27 pm
Offline
Car(s): Black 2.0S with supercharged bike carbs edit; X(in progress)X NOW FULLY OPERATIONAL AND VERY NAUGHTY. Also a white Laser refurbed & parked up & a spare Eaton behind the easychair:-)
Also after you've measured it with a bit of string, add another yard before buying. You'll always find a use for a bit of spare pipe but it would be frustrating to thread it all along the car and find it's an inch short and you need to get another full length!
You might find your local parts shop has a reel of hose with branf name and serial number on it but no psi info. Get them to search google on the chop computer with any brand / serial number plus "psi" or write the available details down and check it yourself - worked for me.
_________________
 Profile
PostPosted: Sat Jul 24, 2010 9:08 am
Offline
Do I really have to use the 2.8I stuff???
Not only I look at it all and think HMMMMMMMMMMMMMMM not really the best place for it.
But the idea I have in mind may cost a few quid more but would serve better in the long run.
My idea is to use a 2litre tank and have a fuel pump run off that lines under the car to filter then on to the injection unit BUT I believe I need a swirl pot between the pump and the injection unit-as I understand it this is the same set-up used for throttle bodies and they work fine and the ford EFI is a throttle body when you really look at it.
 Profile
PostPosted: Sat Jul 24, 2010 2:38 pm
Offline
Yes, you need a swirl pot, unless you plan to never let the fuel level in your tank go below about 1/3. Otherwise air will get sucked in on cornering.
I wouldn't bother with getting bits of a 2.8. If you can get a good 2.8 tank (they have an internal swirl pot) for a good price then go for it, but they tend to catch muck of the road around the fuel pump and rot out there.
Do a google image search for swirl pot for some diagrams of connecting one up. Check ebay for cheap swirl pots and fuel pumps. You could either mount it in the engine bay or find a good spot under the car, like where the fuel accumulator goes on the 2.8 (which you don't need for EFI):
http://cgi.ebay.co.uk/2lt-Bulkhead-Moun ... _711wt_913
_________________
 Profile
PostPosted: Sat Jul 24, 2010 6:29 pm
Offline
Beakster let me see if I am reading you right
All I really need to fuel the Pinto EFI is the 2.8I tank (which I have) the fuel pump and the filter I don't need that fuel accumulator.
Are you running this on you cossie??
 Profile
PostPosted: Sat Jul 24, 2010 6:40 pm
Offline
Hey,
My Cossie was a 2.8 to start with so I'm using the system that is in place.
Capri Andy fitted a 2.9 EFI to his 2.0 Laser. He put a 2.8 tank and pump on and replaced the old fuel hose with high pressure injection hose. He used a fuel filter from a Granada.
James that was in the East Berks club put a Cossie in his mk1 Capri. He did this with a low pressure (lift) pump, swirl pot, injection pump.
Like I said, if you can find a good 2.8 tank for a good price then thats a nice way to do it. Otherwise get a swirl pot.
You don't need the fuel lines from a 2.8 and I would advise against using them, use new injection hose instead. You don't need the fuel accumulator from a 2.8 if you are going EFI. You don't need a fuel filter from a 2.8, these are available new from motorfactors and many other places.
_________________
 Profile
PostPosted: Sat Jul 24, 2010 6:47 pm
Offline
Just spotted you said you already have a 2.8 tank....
In that case, bolt the 2.8 tank in place, make sure you have the fuel pump bracket, get a 2.8 fuel pump:
http://cgi.ebay.co.uk/FORD-CAPRI-2-8-in ... _738wt_913
Get an injection fuel filter and put it where ever you like, under the car would be good as it would be hidden, or bolted to the inner wing like the 2.8. So fuel hose goes Tank -> Pump -> Filter -> Fuel rail on engine. Then you will have a return line going from the fuel rail to the tank. The return line doesnt have to be high pressure.
_________________
 Profile
PostPosted: Sat Jul 24, 2010 7:02 pm
Offline
Cool nice one
just PM'd Andy see how he find the system in general along with the wiring of the fuel pump
think I've got the basic but now just work out this safety switch thing.
I am very new to this EFI thing.
 Profile
PostPosted: Sat Jul 24, 2010 7:06 pm
Offline
When you say "safety switch" do you mean the inertia cut off? I'm not using one and I'm pretty sure Andy isn't either, that said though it is a good idea to use one.
My pump is wired as per the 24v Cosworth wiring diagram, so there is a wire from the fuel pump relay to the pump, and the other side of the pump is earthed. I'm using the fuel pump relay from the Granada, not the original Capri one.
_________________
 Profile
PostPosted: Sat Jul 24, 2010 7:18 pm
Offline
I believe that would be it, I would have figured that ford would have the fuel pump wired off the ECU.
I would just rather that if something does happen I wont have much fuel getting chucked all over the place.
 Profile
Display posts from previous:  Sort by
Who is online
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
Search for:
Jump to:
