replacing engines
- Car(s): MKIII capri 2.0 laser. Bought for cheap and looking to restore and upgrade
replacing engines
I have been offered a 3.0 engine and gear box for my capri. Is it possible to replace the existing 2.0 engine with this?
Re: replacing engines
Yup, been done many times before.
you need the right gearbox, crossmember and radiator, basicly you need the whole package.
ive been given the engine and gearbox for free. are all the mounting the same
And the steering rack unless you want to mod' the 3 litre x member to fit your original rack
- rich_jc
Some would argue it would also be worth welding a few strenghtening plates to the strut tops and towers, as the essex lump weighs quite a bit more than a pinto. 3.0's had them from factory.
Id love to essex my car, but I just don't think id get the same handling characterisitics out of such a big engine compared to how the pinto is.
Rich
Rich
My car is a 3.0'd 2 litre GL, works absolutely fine and does handle quite well. In mine the whole package was carried over but the power steering was left off, makes it a bum to park but fun to drive. I've not had the welding done either, because I'm lazy. I've never had any problems, but if I was involved in a head on crash I don't think the car would come out too well, structurally, due to all that extra weight without the extra rigidity. The Essex is an awesome engine, although very thirsty. I use mine as a daily driver, but wouldn't reccommend it!
In terms of andling, mine is pretty much sorted, it's got a strut brace, 2.8 suspension (120lb I think) in the front, single leafs, 1.5" lowered and x frame in the rear. Apart from needing a new steering rack, it handles rather well, considering!
Oh, and the noise is awesome... a beautiful soundtrack.
