My capri has a std 2.0 L pinto, it has the std twin choke weber. i want to build an engine that gives about 130 bhp without twin dcoe. i have a nice 4 branch and big bore exhaust, electronic dizzy.
i dont want to spend hundreds on a 2.1 with BVH , farndon crank etc.(2 x 45 dcoe 9 10 mpg) its abudget build. The engine is abit smokey , so it will be replaced soon.
Thoughts are
Freshen up bottom end, maybe go to 2.1
RS2000 head , ported andpolished by me
the exhaust as mentioned above
single 45 dcoe on a k&n
Electronic dizzy
Good set up on a rolling road
any ideas, will i hit the 130bhp mark
cheers
neil
A GOOD PINTO ENGINE
- Car(s): 1986 Silver Laser 1.6 Laser, fitted with 2.0L pinto. D228 MOM
- rich_jc
Re: A GOOD PINTO ENGINE
Forget the side draught, get a Kent FR32 cam, K&N filter, 4 branch manifold with a one box free flowing exhaust system, get it set up properly on a rolling road and you should get close to 130bhp on the standard 32/36 carb.
I believe manifolds for a single sidedraught are very hard to get hold of.
Rich
Rich
And theres your 130 bhp...ish!rich_jc wrote:Forget the side draught, get a Kent FR32 cam, K&N filter, 4 branch manifold with a one box free flowing exhaust system, get it set up properly on a rolling road and you should get close to 130bhp on the standard 32/36 carb.
Rich
You need a 40 though head skim while you freshen the top end up, you need good compression, so make sure the bottom end is ok, you are looking for 11.5-12.00 bar compression, a good well run in bottom end with a 40 though skim should make that, if your brave go for a 60 thou.
idealy you want an injection head, these flow very slightly better than a standard one but it aint that noticable out on the road, these are still out there for not much and have unleaded seats as standard.
the standard 32/36 is easy capable so dont touch it, its a good carb.
FR32 cam is very easy to live with (in my opinion too tame) but if you can live a little loss of low end torque an FR33 is worth another 4 or so horses.
any of the 4 branches will flow well at 130 brake so theres no need to spend loads there, as is the case with the exaust, most branded ones make the power.
But do you want 130 at the flywheel or wheels?
- Car(s): .
Preacher Man, does your sweet talking son have anyone to talk to now Dusty has gone?
invalid man , do you my son?
if so , come and teach him how to look after is festa , i am fed up with telling him. some twat nicked his spare wheel from underneath hiscar
A local garage will refurb the bottom end at a cost of £800 , this includes new pistons , new bearings , shells, oil pump and re bored to 2.1.
He can refurb the head at a cost of £300 , this includes conversion to unleaded.but no head work.
aT £1,100 for an engine rebuild , this means the engine will be worth more than the car is worth now [ about £800 ]. I will be looking at an alternative route. I dont mind getting the spanners out and having a go myself and at these prices i will be.
Is an RS2000 engine better , i heard they chuck out about 110bhp with is about 10 more than a bog standard capri. so many options..........so little cash
- Car(s): Rat - GONE
Injection engine from scrap Granada/Sierra £100 (205 block and unleaded head). Fuel tank and pump from 2.8 £70. Bolt in engine, simple wire up job to get it running. You've already got a decent manifold and system so should get over 120 bhp just from this alone. Burtons do an injection cam, no idea if it's any good but should be enough to tip you over the 130 that you want. Easy!
- georgezippybungle
- Car(s): Ford Capri 2.1EFi Laser
BMW 325i touring
If you do an injection conversion, a standard BHP will be about 115 at flywheel but the car will be so much more responsive it will feel faster. I recently owned a 2.0i Sierra with the only mod being a 4 branch. it felt faster than a standard 2.0 capri despite being heavier. You'll get fuel economy in the 30's too. I think it's the most sensible conversion to do, although it's getting harder to find the bits.
