Pardon the slight mis-quote, but I'm sure you get my gist.
Just make sure you don't get Major Tom's jism...
Efi conversion
- Car(s): .
[OO]===o===[OO] - Location: Playing touch-cock with the troll(s)
Re: Efi conversion
THE trollkiller. Oh yes! NEXT!
Re: Efi conversion
however bike carbs with megajolt set up on the rollers will see more power with similar fuel economy, but i can see the point in efi as well
- Car(s): .
Re: Efi conversion
That is true and either will make a good foundation upon which to base a megasquirt bike throttle body set up.
Once set up bike carbs tend to stay on tune a bit better than car carbs.
Bike carbs or efi?
Bike carbs edge it for power.
Efi edges it for economy/ reliability.
But which is best? There's only one way to find out...
Bike carbs or efi?
- Car(s): Rat - GONE
Re: Efi conversion
"Set up" on the rat was non - existent. the engine was brought home from the scrappy, flywheel fitted (it was an auto) and then it was thrown (almost literally) into the car. Wires twisted together, key turned and it ran. And ran well. A bit of tidying up, but not much and it is now as it was then.
- Car(s): .
Re: Efi conversion
It really is that easy!340truck wrote:"Set up" on the rat was non - existent. the engine was brought home from the scrappy, flywheel fitted (it was an auto) and then it was thrown (almost literally) into the car. Wires twisted together, key turned and it ran. And ran well. A bit of tidying up, but not much and it is now as it was then.
- Car(s): 1983 Ford Capri S 2.9 EFI
Re: Efi conversion
InvalidBoy wrote:It really is that easy!340truck wrote:"Set up" on the rat was non - existent. the engine was brought home from the scrappy, flywheel fitted (it was an auto) and then it was thrown (almost literally) into the car. Wires twisted together, key turned and it ran. And ran well. A bit of tidying up, but not much and it is now as it was then.
Ha Ha, unless u fiddle!
Re: Efi conversion
There is a way to get the best of both bike carbs and efi
Bike throttle bodies and megasquirt
Though I have been setting this up for a year and its still not quite finished.
- georgezippybungle
- Car(s): Ford Capri 2.1EFi Laser
BMW 325i touring
Re: Efi conversion
Yes been dabbling with BMW's and doing up the house, not driving Capris, poor thing has been languishing in the garage forgotten about, and I lost my login on this site when it moved.rich_jc wrote:I know you lot rave about it, but surely its just easier to get a carb built up properly init?
And yes, welcome back Mr.Bungle, you were the first guy I ever spoke to on the board years ago about electronic ignition.
Rich
But I'm back and so is the 2.1, another good thing about EFi, start it after 4 months of standing in the garage, and it does 250 miles up the motorway faultlessly the same day.
- Car(s): REBUILDING 2.0 PINTO SUPERCHARGED WITH RS KIT
Re: Efi conversion
JUST TO BE ANNOYING DOES ANY ONE KNOW THE WIRE COLOURS AND DESTINATIONS TO JUST THE EFI, I HAVE BEEN TOLD THERE IS ONLY THREE THAT I NEED AND ALL I HAVE IS THIS DIAGRAM
