water leak
water leak
q / i have a water leak when it rains it drips down near the heater outlet on the passenger side where does the leak come from
Re: water leak
The water nearly always comes from the windscreen seal so this is the first place you should check. I recommend you buy a tube of sealant (the best stuff is that rain / gutter sealant as it stays soft) and use one of those trigger gun things. Cut the very tip of the nozzle and then you should be able to get it under the rubber seal. Start pumping and move all the way round the seal. You will use up the best part of a tube doing the front screen. Afterwards use a plastic scraper to remove excess. You may have to repeat after a few days as more sealant oozes out
