Can anyone tell me where I can get a spare side repeater light for my Mk III Laser 1.6? I also need to find a stockist for a new brake calliper for the same car?
side repeater lights
Side repeater lights
If you just need a bulb then you can get these from any Motor Factors. If you require a new light fitting then I suggest you try the companies listed in my spares section on this web page. They all do mail order! You will also be able to get a caliper from here as well. Although are you sure that the caliper is knackered because you can overhaul them with a new piston / o-ring kit. The caliper itself is just two blocks of cast iron bolted together. There is a description of how to remove it in my work section under 'front wheel bearings'
