I have a 1985 Ford Capri Laser and the brake lights,indicators and instrument cluster lights have started to play up. The indicators and brakelights have stopped working and when I press the brake pedal the rev counter goes to zero and the charge light comes on. I think there is a short some where does anyone have any ideas about this please.
I had a very similar problem once in my 1.6 Laser. All i did to get 'round it was take all the fuses out, clean the contacts and replace them all (making sure they went in the correct slot). I know it sounds odd but it worked for me, give it a try - you never know !
Definately sounds like an earth problem. Try checking all the connections to the headlights. A rusted connection will cause the problems you are describing. Also check the rear number plate light connections.
