do mk2 ford capri parts fit on to the mk3s with no problem?
or do you have to modify it?
cheers m8
Do Mk2..
mostly, yes.
The MkII and III were mechanically identical. The only differences between them were front wings, bonnet, front panel, headlights and grille.
Mechanical parts like running gear will the be the same between them. Body panels vary slightly (as I said) and the interiors are largely the same.
Only for completion...
...the rear lights also vary, they are bigger and have those "Mercedes-like steps" on the MK III
Marco
xxx
Marco
xxx
