Heater
Craig Adamson
Heater
Post by Craig Adamson »
Well, it had to happen, what with winter just around the corner, my blower has stopped blowing !
Am i right in thinking that it's a right pig to get at (Dashboard out, feet out the sunroof with ya head under whats left of the dash !!!).
If anyone knows of an easy repair please let me know.
Craig.
Mark 280
you're not wrong!
Post by Mark 280 »
Sorry mate ,but it is a sod to get to,first thing to do is make sure its not something simple thats gone,ie:-switch,fuse,bad connection ect.
I found the easiest way to deal with it was to remove every thing in the way(all the underside of the dash),then you can see where you are working.the fault on mine was actually the connection block to the motor,for some reason it had got water in there and got corroded.I thought at first the motor had gone but it wasn't the case.
It was a 2 minute job to fix and an hour to put the glove box ect back.
Hope you get it sorted O.K,Mark
Gavin
Its Easy
Post by Gavin »
I did this a couple of years ago. Basically you just disconnect the cables from the 'black box' unbolt it and slide it towards the pedals. Took me 10 mins to get out.
