Temp sensor bullet connector
Hi chaps im doing a little clean up of the engine bay as its got a bit tatty since my resto a couple of years back ,with the heat of the engine and a bit of condensation and the car been sat in a lock up has made a few things a bit tatty so i wonder if anyone can help, the wire/bullet conector which connects/push fits to the temp sensor is missing /bodged on my car. where can i get a connector with wire attached and also the rev cable where it connects to the linkage to the carb has surface rust on.do i paint it or bare metal it and grease it ,galvanised paint etc. i polished it up before but it gets surface rust on after a while.any help is much appreciated.cheers mel
Re: Temp sensor bullet connector
I'd try CapriGear for your connector - https://caprigear.co.uk/
As a regular user of this forum you can PM him on here too, I've found he replies very quickly to help.
Cheers il give him a go.ive had a few bits off him before.
I agree with Paul Martin will send you the right one as well
Is Martin back from his holidays yet ?
Don’t know he went to that nudist beach in Spain for two weeks to top up his tan . Must be back now
I am sure that’s what I read on his Facebook page
Yes Martin is back
Me too. He really knows his stuff on Flog It.
I looked everywhere for a replacement bullet connector for the temp sender, but I just couldn't find one that was a good match for the original.
Luckily Martin was able to supply one with a short length of the correct wire attached.
A secondhand one is your only hope if you strive for an original style item
Had you down as a Dickson real deal Andrew
Gotta love The Duke.
What a Bobby Dazzler!
Been it touch and he has one.ordered summat else as well .
Ford Sierra XR4x4 2.9 1992
Quick one..my temp sensor died on my BOA Cossie and I replaced it with a genuine Ford item for the BOA, mine had a kind of screw on bullet, which was quite rusted so I cleaned it up with steel wool and WD40 before screwing it back on the new sensor. However she now only reads max the bottom level on the gauge even when full operating temperature...(before , she went to the second one up)
Not sure why if it’s a new sensor, or could it be the bullet screw connection that is on its way out....
Sierra XR4x4 2.9i 1992
Jaguar XJR 4.0 SC 2001
Jaguar F-Type 3.0S sc 380
sorry that should read BOB not BOA
I changed the sensor for a brand new one..the bullet connection with a proper one, mmm she still sits on the lowest possible reading even after a 20 mile run in 95 degree heat....could the wire be on its way out?
Did you get the one with the white collar?80s-new-man wrote: ↑Thu Jul 25, 2019 8:07 pm I changed the sensor for a brand new one..the bullet connection with a proper one, mmm she still sits on the lowest possible reading even after a 20 mile run in 95 degree heat....
Hi Andy, It’s one with , like a 90 degree black connector, from a scrap 2.8i ..
I have changed the wire, as I noticed that the wire when I cut it, was rather black inside, so that didn’t look right.
Gonna take her out for a 10 mile run when I take my daughter to work tonight so will see what happens..
Good luck, hopefully that will work.80s-new-man wrote: ↑Tue Jul 30, 2019 5:05 pm Gonna take her out for a 10 mile run when I take my daughter to work tonight so will see what happens..
The sensor must be one with a white collar below where the bullet connector attaches, like this one:
If that collar is any colour other than white, it will give an incorrect temperature reading.
Andy thanks..
I think all along I had misunderstood- I thought the actual connector with wire had to be white. In fact it’s black.
The connector ON the actual sensor...well, that is a turquoise colour as I had ordered it for the Granada/Scorpio, thinking that is the correct one for her engine.
So now I’m gonna order a sensor with the white collar...hopefully that will put it right!
Thanks!
Stu
Thanks!
Stu
Hang about Stu, I've only just noticed that you've got a 2.9 Cosworth engine, not a standard Capri engine. It would be best to check with somebody like Tickover to determine which is the correct sensor for your particular application.80s-new-man wrote: ↑Thu Aug 01, 2019 7:03 am So now I’m gonna order a sensor with the white collar...hopefully that will put it right!
Ah well that’s ok Andy, I ordered one of the white/grey collar from fleabay for 8 quid , now I’ll have both !
