My poor DeWalt is getting a hiding with all the wire brushing and the like, so I'm wondering if it's worth investing in a compressor and some air tools. Air sander to start with that will take 2" and 3" ROLOC discs, and then an HVLP spray gun. I've used SGS in the past and they do this little beastie for cheap money, but maybe not going to be man enough for paint?
https://www.sgs-engineering.com/sc6h-6- ... compressor
Maybe need a bigger tank, so perhaps..
https://www.sgs-engineering.com/sc24h-2 ... compressor
They do some deals to so might look at those
Air Tools & Compressors?
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Re: Air Tools & Compressors?
The first one is definitely too small. SGS sell the second one as part of a painting kit so it should be ok although I suspect it will be near its limit reading the specs.
I hate air tools, much prefer electric. Are you using a drill for wire brushing? If so use cheap a one as it ruins them in no time, or can you not use a grinder (much more effective)? I have a small Metabo electric sander which takes ROLOC discs so even that kind of thing is available these days; i just don’t have a need for a compressor at home. I’m probably in the minority but having used air tools at work for years in the past I just don’t like them; if you’re painting I can understand it though.
One further thing to consider is whether you need an air fed mask; if so you’ll certainly need a much larger compressor along with suitable filtration.
Although I haven't used it with air power tools (I'm inclined to think you need something quite beefy for such things), I would certainly recommend the Aldi compressors, if they come back in near you, they often come with great accessories too -
+1 for the Aldi compressor. Fantastic for the price and certainly strong enough for most jobs you would encounter
W- Mondeo 2.0 Ghia Estate
03 Focus 1.6
Seconded re wire brushing - I have a cheapo screwfix own make drill, which cost in the region of £30-40, specifically for this job (or as an overkill electric screwdriver) to avoid damaging quality ones.mjcapri wrote: ↑Thu Jun 27, 2019 6:37 am The first one is definitely too small. SGS sell the second one as part of a painting kit so it should be ok although I suspect it will be near its limit reading the specs.
I have the next one up from this with the 50 litre tank and it's been OK, will keep up enough pressure to spray but motor cuts in after a couple of panels but air tools generally won't run for long without needing it to fill the tank again.(which is does quite quickly).Cosmicbike wrote: ↑Wed Jun 26, 2019 7:17 pm My poor DeWalt is getting a hiding with all the wire brushing and the like, so I'm wondering if it's worth investing in a compressor and some air tools. Air sander to start with that will take 2" and 3" ROLOC discs, and then an HVLP spray gun. I've used SGS in the past and they do this little beastie for cheap money, but maybe not going to be man enough for paint?
I wish I could have gone for the next one up with 100 litre tank but don't have the space.
The air tools they give away with it (mine came with windy gun, air saw, DA sander etc) and not very good to say the least and you have to use the metric air connectors too.
