2.8i back from MOT today (no advisories) and getting tappets set (do it - much faster now).
Had a long standing drip leak from bottom hose / thermostat housing. Had mucked about trying to make the bottom hose reseal, but gave up and left it to the garage who did MOT and valve clearences.
Anyway heres what happened when it came off:
Lucky escape there! Been like that a few years and obviously the crack was quite old as its not exactly clean metal is it!!!
They also found a split on the air intake hose, but had one IN STOCK - lucky day.
Thermostat of death
Re: Thermostat of death
I would say you had the money out of that , funny as everybody’s housing seems to be needing to change .
Also glad she passed mot ok
Hi Noel , Wow mate, that housing has seen better days. Great it was found before it caused damage and well done on the mot. Nice one Noel
Great news that you car has passed it's MOT with no advisories Noel, now you're ready for another year of motoring joy!
I've had exactly the same thermostat issue that you've illustrated here. The aluminium castings seem to be quite weak at those lugs and are vulnerable to overtightening. Thank goodness that reproduction items are available.
Nice commemorative royal mug.
- Noel
- Car(s): Capri 2.8i
M140i - Location: Twickenham
Well spotted on the mug.
Funny how it had been dripping for about 4 years but I never thought it was anything that serious.
I remember a 2 hour crawl round the M25 at about 5mph on a saturday afternoon last July when it was about 30C in the shade. Imagine if it had let go then eh? Very lucky. I bought the replacement housing some time ago but had it as a low priority job.
Looking at the radiator now everything else is up to scratch mechanically:
Wonder if its time for a replacement? Have had no problems with cooling at all, but its getting quite flaky. Been recored 20 years ago so perhaps time to do it again?
I always lean on the side of caution with my rads - if it goes one day and cooks the engine you're worse off than you would be if you got a new rad or had the current one re-cored... my thoughts anyway
Ironically, I’m in the same predicament . Just changed my water pump as I had a slight leak to!
Luckily enough, my thermostat housing was in good shape so just changed the stat. Unfortunately, the new one didn’t sit right and when I filled up with water it pissed out! Changed back to the original stat because it was working ok.
Put it all back together again, filled it up with water first then all good!
Let it run, cooled it down then drained off a load and filled with anti freeze.
Seems all ok now.
Now the radiator. I was thinking the same once I had taken mine out. Ok for now but am looking into getting a new one.
Contemplating an aluminium one but don’t think it’ll look right.
Decisions decisions!
Seems all ok now.
- Noel
Will be re-coring mine when I get round to it, as it keeps the correct look. I think there are some places that will add a three row core to the standard rads, but I have never had cooling issues with the stock item.
