What is it?
Re: What is it?
Post by andyd » Wed Nov 07, 2018 5:37 pm
andyd wrote:I was planning on doing the oil and filter, but thought as it's just sat in the garage I may as well do it in March.
Do you usually change yours this time of year??
Looking from the front of the car, where abouts is the drain plug located and can you get to it wihout jacking the car up??
Hi Andy,
No, I usually leave the oil change until after the winter, but I felt like a change this year. I personally feel that it doesn't make any real difference when it's done, as long as it's done.
The filler plug is on the right hand side as you look from the front. The sump plug is easy to reach without jacking the car up. The filter can be reached from behind the offside wheel, although you might find it easier to raise the car a little to get to it easier.
:cheers: Andrew
Re: What is it?
Post by Andrew 2.8i » Wed Nov 07, 2018 6:55 pm
andyd wrote: :cheers: Andrew
No problem. I forgot to ask if your filter is on a hanger, I assumed so? The Ford workshop manual has a diagram that shows the filter screwed directly to the oil cooler, so I would hazard a guess that some cars didn't have them fitted.
You can get to the filter from the front of the car if you jack the car up, but with access from the position shown you may not have to. It depends on which tool you use, I suppose.
Re: What is it?
Post by andyd » Wed Nov 07, 2018 7:30 pm
:D
I can see the bottom half of the filter from behind the o s f wheel. My mate has a tool to get it off but not sure which one though.
So looking at your arrow, the sump plug is basically on the r/h side of the sump under the dipstick tube??
Re: What is it?
Post by Andrew 2.8i » Wed Nov 07, 2018 7:34 pm
andyd wrote:So looking at your arrow, the sump plug is basically on the r/h side of the sump under the dipstick tube??
Yes it is.
Re: What is it?
Post by andyd » Wed Nov 07, 2018 7:38 pm
Yes it is.
:cheers: That's my next job.
This is the sump plug I bought https://www.ebay.co.uk/itm/COLOGNE-V6-D ... SwNYRZmzFa Which washer would you use?
Re: What is it?
Post by Jasonmarie » Wed Nov 07, 2018 7:41 pm
Jasonmarie wrote:Y Our local council was giving grants for solar panels on the roof but they said they would need changing in 7 years time that worked out a lot of money .
We asked about it, but they only give grants to properties with a south facing roof in order to get the maximum return. We don't see as much sun here as you get in the south east. Now, if only there was a way to generate electricity from rainfall we'd be on to a winner! :)
Yes very true with the rain , yes with the electric you sell back to the company what you don’t use I can’t remember the cost , also we would have had them on the front what would have stuck out .
I can only guess things will get cheaper also the new houses they are building up the road don’t have any gas going to the houses it’s all electric.
Re: What is it?
Post by Andrew 2.8i » Wed Nov 07, 2018 10:30 pm
andyd wrote:is is the sump plug I bought https://www.ebay.co.uk/itm/COLOGNE-V6-D ... SwNYRZmzFa Which washer would you use?
Of those, I would use the nylon one. I tend to use a copper one on mine though. I've also got a magnetic sump plug. I'm not sure if it works with regards to attracting metal particles in the oil. However, it does come in handy when draining the oil, because if you accidentally let go of it when unscrewing it, it doesn't fall into the container of used oil but it sticks to the sump. :D
Re: What is it?
Post by andyd » Thu Nov 08, 2018 7:16 am
I thought dropping the sump plug into hot oil was all part of the fun :?
:cheers: Again Andrew.
Re: What is it?
Post by Andrew 2.8i » Thu Nov 08, 2018 7:41 pm
andyd wrote:I thought dropping the sump plug into hot oil was all part of the fun :?
I take it you usually run the engine beforehand then?
This is the sump plug I bought, if anybody is interested:
https://www.ebay.co.uk/itm/Ford-Capri-R ... :rk:2:pf:0
Re: What is it?
Post by andyd » Thu Nov 08, 2018 7:49 pm
Thanks for the link, I have bookmarked it for future reference.
I never used to, but the last few times I have run the engine first as I was led to believe the oil drained better when warm....Old wives tale :?
You change yours when cold ??
Re: What is it?
Post by Andrew 2.8i » Thu Nov 08, 2018 8:28 pm
andyd wrote:I never used to, but the last few times I have run the engine first as I was led to believe the oil drained better when warm....Old wives tale :?
I have heard that the oil is thinner when warm, and therefore will drain easier. The question I ask is, does the oil not drain when it's cold? I don't think so. I let it drain, leave it for a bit while I go off and do something else (cup of tea and lunch, usually) and then return to it. As a precaution, I leave myself a note on the steering wheel that says "Do not start", just in case I forget what I was doing when I return from lunch! :lol:
andyd wrote:You change yours when cold ??
Yes.
Re: What is it?
Post by Jasonmarie » Thu Nov 08, 2018 8:32 pm
That’s the start of nearing 50 mate when you leave yourself a note must say I also do that ....
Re: What is it?
Post by andyd » Thu Nov 08, 2018 8:34 pm
Jasonmarie wrote:That’s the start of nearing 50 mate when you leave yourself a note must say I also do that ....
When you get over 50, by the time you get the paper you've forgotton what you were going to write :?
Re: What is it?
Post by Andrew 2.8i » Fri Nov 09, 2018 6:52 pm
Jasonmarie wrote:When you get over 50, by the time you get the paper you've forgotton what you were going to write :?
I'm like that sometimes, I......…...nope. Forgot what I was going to type! :)
Re: What is it?
Post by Jasonmarie » Sat Nov 10, 2018 11:37 am
:lol: what was we talking about :lol:
