Tank sender wires
Alanb67
Car(s): Ford capri 1.6L
Tank sender wires
Postby Alanb67 » Wed Sep 12, 2018 7:39 am
Thanks in advance. What way round do the fuel tank sender wires go. Took them off a while ago now forget which one goes where... :oops:
Re: Tank sender wires
Postby Peter-S » Wed Sep 12, 2018 4:46 pm
Alanb67 wrote:Thanks in advance. What way round do the fuel tank sender wires go. Took them off a while ago now forget which one goes where... :oops:
Unless you have taken the connectors off the wires they will only fit one way as one connector is bigger than the other. If you have removed the connector then the blue wire goes to the thicker central terminal and the brown one to the smaller terminal.
