Front grill
Dreamachine
Car(s): Ford capri 2.0 restoration project
Ford focus daily driver
Front grill
Post by Dreamachine »
Anybody know what year they changed the badge on the front grille :?:
Re: Front grill
If you're talking about the Mk3, they didn't.
Re: Front grill
If you mean the mesh grille that had FORD written on, they are from the Mk2 cars ('74-'78) and then all the Mk3 cars ('78-87) had the plastic grill with the ford badge on the front
You can put a Mk2 grille on a mk3 car as the screw-holes are in the same place and it is quite a common change. In fact a lot of the MK2 guys get annoyed that the Mk3 guys always take all the grilles! :lol:
Dreamachine
Re: Front grill
Well mines got the white ford name on the front not the oval ford badge :ford:
Dreamachine
Re: Front grill
The previous owner must of changed it then coz mines 82
Dreamachine
Re: Front grill
Any preference to whether should change it or stick with the mk2 grille
Re: Front grill
Dreamachine wrote:Any preference to whether should change it or stick with the mk2 grille
It's your car and you should have it how you want it :) But always keep the original parts so it can be put back to standard if or when you want.
Dreamachine
Re: Front grill
Ok cheers guys..think will stick with the mk2
Arya2.0S
Car(s): ford capri 2.0 s
Re: Front grill
Post by Arya2.0S »
D366Y wrote:If you mean the mesh grille that had FORD written on, they are from the Mk2 cars ('74-'78) and then all the Mk3 cars ('78-87) had the plastic grill with the ford badge on the front
The holes might line up but you'll need to drill out the spot welds and remove the extra lower mounting lugs ford welded on especially for the mk3 grille. Unless you bend them backwards or remove them completely the mk2 will not fit.
