Anyone know
Cockneyreject
Car(s): Ford Capri 3.0s
Classic mini Paul smith edition
Anyone know
Post by Cockneyreject »
Hi people,so have just picked up my new 3.0s
Quick question or so.
How can I tell if need lead additive or can run freely on unleaded?
How can you tell if has fibre or steel timing gear?
Does anyone know where I could pick up the small rs centre steering wheel cap?
Will probably have a few more as crawling all over it today.
Oh yeah bonnet release seems very stiff almost to the point of breaking when pulling,I don't remember that from my previous 2.8i etc,but has been 20 years since I have owned one
All the same absolutly over the moon,nothing like that driving position and v6 burble :drive:
Cockneyreject
Re: Anyone know
Ah forgot sunroof.
So opens and closes ok(bit stiff) on slide mechanism,but won't tilt,and yes I know has switch,but both positions only do slide?
Re: Anyone know
Post by Paul G »
A standard 3.0S would need lead additive and would have a fibre timing gear. The best thing on both these is to ask the previous owner and if he/she doesn't know then I'd assume that it hasn't been modified. Sometimes the steel timing gears will whine a bit which would indicate one is fitted but the only safe way of knowing is to strip it all out and see for yourself.
Can't help you with the RS badge - do you mean the cap with the two flags as fitted to a MK2 S or the proper RS cap? Ebay or ask the various breakers/parts suppliers.
The bonnet cable should not be too stiff - try greasing the bonnet latch and if that doesn't work then probably it's best to put a new cable on. Mine snapped on my 3.0S but I managed to get the grille off to get it open.
Sunroof sounds like a problem in the winder mechanism, sorry i don't know enough about them.
Cockneyreject
Re: Anyone know
Thanks fa reply.
Kinda thought I'd need to add additive,just wondered if anyway of telling,same as timing gear,without dismantling it all.
In future was poss planning an engine overhaul that would mean unleaded heads,timing gear fast road cam,oil pump,etc,memories of years back I remember the Essex v6 responds well to this.
Indicators are not turning off automatically,and passenger side wiper just packed up.(knew I shouldn't have gone out in the wet)
Ah the joys of having a classic back.love it.
Yes the rs logo on steering wheel,not the big padded one,I see one on eBay bet my old one was just a pop in/out one.probably scour auto jumbles at car shows.
Re: Anyone know
Get yourself to Powderham Historic Show next weekend 8th/9th July, lots of trade stand there https://historic-vehicle-gathering.info/
Between Exeter and Dawlish.
I will be there both days with the XR Owners Club :D
Andy
P.S. You have an unread Private Message, check your Inbox.
Re: Anyone know
Post by Paul G »
Cockneyreject wrote:Thanks fa reply.
Re the wiper, is it just the nut come loose that holds the wiper arm on to the spindle?
Re: Anyone know
Think we need some pictures in the members section glad to here your driving in the rain and enjoying the car I bet you have still got that big :D grin we all have now .
Arya2.0S
Car(s): ford capri 2.0 s
Re: Anyone know
Post by Arya2.0S »
Take the steering wheel off and check to see if the small plastic tab behind it that self cancels the indicators is broken. All it is is a plastic sleeve that goes over the steering column with a plastic tab that sits into a small hole in the steering wheel which turns with the wheel and cancels the indicators. If this is broken and not holding into the wheel then that will be your problem, and should be a cheap and easy fix as long as you can find a replacement. Try Capri Gear for stuff like that.
Re: Anyone know
Post by Not_Anumber »
Sometimes the sleeve/ tab for cancelling indicators is present on the column but just wrongly aligned. If so it just needs sliding off and putting back on the right way. Ive had this twice on different cars over the years.
Cockneyreject
Re: Anyone know
Hi all yup chqed the nut that is all good, wiper just flops about, I suspect has popped out of mechanism,
And I will look at indicator stalk steering wheel tomorrow
If I get the time, thanks all, great site for info, and yes may pop up to donkey sanctuary after work and or Powderham. And introduce myself. Again thanks all.
Good to be back :drive:
