Page 2 of 3
Re: Ford TX Torch Key
Posted: Wed Oct 12, 2016 5:53 pm
by Stish704
I got a new battery but then no the bulb has gone. Now, where would I get one of them?
Posted: Thu Oct 13, 2016 4:42 am
by Andrew 2.8i
Hi Nick,
I think you've bought the torch key at a good price.
When you get it cut, make sure they put the pointy end in the machine.
Posted: Thu Oct 13, 2016 4:49 am
by Andrew 2.8i
Stish704 wrote:I got a new battery but then no the bulb has gone. Now, where would I get one of them?
Check the dimensions of this one against the Ford item, with a bit of luck they'll be the same.
http://www.ebay.co.uk/itm/VAUXHALL-ASTR ... noapp=true
Failing that, the battery and bulb unit can be purchased as a whole.
Posted: Thu Oct 13, 2016 4:46 pm
by Fordoholic Nick
Hi Chaps,
Look what arrived in the post today...
20161013_164640 by
nicholas bowler, on Flickr
It even came fully loaded with bulb and battery....
20161013_164727 by
Andrew 2.8i wrote:I think you've bought the torch key at a good price.
Thanks Andrew, Yes Siree ! I think £50 weren't a bad price at all mate
Andrew 2.8i wrote:When you get it cut, make sure they put the pointy end in the machine.
Jeepers Andrew, you are making me very nervous now fella but you do make a "key" "point" there old chap
Posted: Thu Oct 13, 2016 5:33 pm
by Stish704
Andrew 2.8i wrote:Stish704 wrote:I got a new battery but then no the bulb has gone. Now, where would I get one of them?
Failing that, the battery and bulb unit can bu purchased as a whole.
Thanks mate, will do.
Posted: Fri Oct 21, 2016 8:35 pm
by Fordoholic Nick
I got my TX Torch Key cut today...was a bit worried in case it did not "go to plan" as its not exactly a standard "off the shelf" key that can just be replaced to do it again, but all went fine...phew !
20161021_210147 by
I tried it in the Capri tonight and it fits just fine
Posted: Fri Oct 21, 2016 8:43 pm
by Andrew 2.8i
Fordoholic Nick wrote:I tried it in the Capri tonight and it fits just fine
Terrific!
The perfect finishing touch.
Be sure to try it in all the locks plus the ignition.
Posted: Fri Oct 21, 2016 8:49 pm
by Fordoholic Nick
Andrew 2.8i wrote:Terrific!
Hey, thanks Andrew
I tried it in the drivers door and ignition tonight. Yep, you make a good point to check in all the locks. Will do tomorrow !
All the best mate
Posted: Fri Mar 24, 2017 11:24 am
by ukfpv
Any thoughts on whether the Turkish torch key blanks are fake? From what I know the key should have raised 'dimples' on the Ford emblem side, to match those on the the torch/battery fitting - the Turkish key blank does not have these 'dimples'
Posted: Fri Mar 24, 2017 11:28 am
by Andrew 2.8i
ukfpv wrote:Any thoughts on whether the Turkish torch key blanks are fake?
Welcome to the forum.
You never know, the Turkish keys might have been made over there, and might have slight variations in design when compared to the genuine UK versions.
However, my suspicion is that they are probably not genuine.
Posted: Fri Mar 24, 2017 5:10 pm
by ukfpv
Thanks Andrew
Been lookin' at the forum for a while but have only recently got around to doing anything about it
Hmmmm I guess these things are relatively easy to copy (if that is indeed the case). I wonder whether anybody on here has purchased one and can confirm either way
Regards
Saul
Posted: Fri Mar 24, 2017 7:38 pm
by Jasonmarie
Yes I bought one and it all fits and work and the torch part got to me in two days from eBay .
Posted: Fri Mar 24, 2017 9:27 pm
by tejb1
Many companies make key blanks, so long as they are compatible it's fine. A bit like how you go into the motor factor and ask for an EFL90 oil filter and they translate that to the right stock code for whichever brand of filters they carry in stock.
Posted: Sat Mar 25, 2017 8:28 am
by Andrew 2.8i
tejb1 wrote:Many companies make key blanks, so long as they are compatible it's fine.
A fair point. The Turkish key will work exactly as intended, and as such represents decent value for money.
I assumed the poster, ukfpv, was specifically looking for a key that was definitely a genuine item for authenticity.
Posted: Sat Mar 25, 2017 3:41 pm
by Fordoholic Nick
The key that I bought last year has raised 'dimples' on both sides. I got mine off an ebay seller based in Blighty
When I get in from work tonight if I think I will look up to see if hes still selling.
Posted: Sat Mar 25, 2017 4:16 pm
by Andrew 2.8i
Fordoholic Nick wrote: When I get in from work tonight if I think I will look up to see if hes still selling.
That would be the chap mentioned in the original post, nield44.
He doesn't currently have any torch keys listed on Ebay.
Judging by the cost of 2x NOS TX keys (without torch), I dread to think how much the torch keys would be anyway.
http://www.ebay.co.uk/itm/2-X-ESCORT-MK ... SwWxNYxqiV
I'm glad I bought mine when I did!
Posted: Sat Mar 25, 2017 5:00 pm
by ukfpv
Correct Andrew, I'm endeavouring to get a 'genuine' Ford torch key blank. Thanks guys - I have approached the neild eBay seller, as well as Retro Ford, but they're both currently out of stock - hopefully though I've just agreed to purchase a key from a fello 280 friend of mine so one would hope my problem is now solved
Back to the Turkey seller, I do think they're fake, so although on a par with the genuine item (when in stock) finance wise, a fake is still a fake, especially when prominently being sold as a genuine item
Posted: Fri Mar 31, 2017 6:35 am
by ukfpv
Requiring a GENUINE torch key blank again as my friends key wasn't correct - if anybody has one please let me know
Posted: Wed May 03, 2017 5:01 pm
by Andrew 2.8i
ukfpv wrote: if anybody has one please let me know
Here's one:
http://www.ebay.co.uk/itm/ford-capri-28 ... 6016.l4276
Posted: Sat May 13, 2017 5:40 pm
by Andrew 2.8i
The listing for the torch key has ended. I presume it's been sold.
I've just noticed that it's the same seller that is selling the ropey 280 and the seats mentioned in another thread.
