Report any offensive posts to
[email protected]
Posts: 14724 Joined: Sat Jan 25, 2014 7:38 pm
Car(s): '83 2.8 Injection (sunny days only) '04 Toyota MR2 (owned from new)
Post
by Andrew 2.8i » Mon Mar 23, 2015 7:55 pm
G4242 wrote: The iPad came out to the car just to check and make sure my switches are in the correct order.
Very relieved to say they were, phew
What have I started here? I bet everyone on the forum has gone out to their garages to check their switches!
G4242 wrote: How sad am I.
No sadder than me, if its any consolation!
At least now we can relax, safe in the knowledge that our switch order is as Henry intended!
All the best,
Andrew 2.8i on Tue Mar 24, 2015 1:10 pm, edited 1 time in total.
eloise
Posts: 266 Joined: Fri Apr 24, 2009 2:07 pm
Car(s): 2.9 cosworth inj, S1 rs turbo, t25 campervan, jag xtype, Reno megane, honda c50, Vespa gt200.
Post
by eloise » Mon Mar 23, 2015 9:15 pm
Mine are all out of order but I don't care, I like them where they are
oh no what have i started!
G4242
Posts: 23 Joined: Wed Nov 05, 2014 12:15 am
Car(s): capri
Post
by G4242 » Mon Mar 23, 2015 9:17 pm
eloise wrote: Mine are all out of order but I don't care, I like them where they are
I think you're very brave
MS Injection
Posts: 825 Joined: Wed May 07, 2014 1:03 am
Car(s): 1985 Ford Capri 2.8 Injection Special
Post
by MS Injection » Mon Mar 23, 2015 9:33 pm
Thank goodness mine are in the right place. I might have been driven mad otherwise....
Posts: 4906 Joined: Wed Jul 11, 2012 6:31 pm
Post
by stevemarl » Mon Mar 23, 2015 9:40 pm
That`s just the sort of attitude that`s brought this country to it`s knees - bloody anarchist!
Post
by Andrew 2.8i » Tue Mar 24, 2015 1:16 pm
MS Injection wrote: Thank goodness mine are in the right place. I might have been driven mad otherwise....
Mike,
You had to check, otherwise it definitely would have niggled! You might possibly even have been ostracised from the Cheshire club!
Post
by Andrew 2.8i » Tue Mar 24, 2015 1:19 pm
How can you sleep at night knowing the switches are in a different order?
MS Injection
Post
by MS Injection » Tue Mar 24, 2015 1:47 pm
peers.dupp wrote: Mike,
Correct - one or two bound to notice! It was all indoor work with no heavy lifting though - I have got photos of the interior so I could check without putting down my beer and going out to the car
Mike
Post
by Andrew 2.8i » Tue Mar 24, 2015 2:19 pm
If only all jobs were that easy!
Posts: 7425 Joined: Thu Jun 07, 2012 6:29 pm
Post
by pbar » Tue Mar 24, 2015 2:34 pm
I usually push these out from the back to avoid any damage using the screwdriver prising method, is that how we all do it?
Post
by Andrew 2.8i » Tue Mar 24, 2015 2:40 pm
pbar wrote: I usually push these out from the back to avoid any damage using the screwdriver prising method, is that how we all do it?
That's how I do it. It's a shame previous owners weren't so careful.
Post
by pbar » Tue Mar 24, 2015 2:45 pm
I think the Haynes shows you to prise them out with the screwdriver (in a rag if I remember correctly)!
Post
by Andrew 2.8i » Tue Mar 24, 2015 2:50 pm
pbar wrote: I think the Haynes shows you to prise them out with the screwdriver (in a rag if I remember correctly)!
Yes, that is how it is shown in my Haynes manual too. I'll keep doing it my way..........
Post
by pbar » Tue Mar 24, 2015 2:55 pm
I've always pushed them from the back also, just wondered if anyone else had another method.
Post
by stevemarl » Tue Mar 24, 2015 3:28 pm
I have prised one out `cos it was sticking once, BUT, I prised at each side NOT against the bottom as in Haynes (I think?) as I think this gave squarer leverage with less chance of slipping. Plus 2 layers of masking tape. If it hadn`t worked I`d have done from the back, but it`s so much dismantling...
Post
by pbar » Tue Mar 24, 2015 3:30 pm
stevemarl wrote: If it hadn`t worked I`d have done from the back, but it`s so much dismantling...
The lesser of the evils I guess!
Post
by stevemarl » Tue Mar 24, 2015 3:38 pm
My problem is I`m absolutely obsessed with noises; rattles creaks, vibrations - they do my head in! I`m always afraid if I take the dash panels off, when I put it back there`ll be something that`s moved and is now touching something else and causing an untraceable `tap...tap..tap.... And ^THAT is why I prised it out....
Post
by pbar » Tue Mar 24, 2015 3:41 pm
I know what you mean Steve, these old cars are not shy with their rattles and squeaks, especially the plastics, and especially in hot weather. Your previous tip using foam/sticky backed foam/draught excluder type stuff (or similar) is a good one. I have used rubber washers in places, where plastics are screwed together which also works wonders.
Post
by Andrew 2.8i » Tue Mar 24, 2015 7:41 pm
stevemarl wrote: My problem is I`m absolutely obsessed with noises; rattles creaks, vibrations - they do my head in! I`m always afraid if I take the dash panels off, when I put it back there`ll be something that`s moved and is now touching something else and causing an untraceable `tap...tap..tap.... And ^THAT is why I prised it out....
Steve,
Prising the switch out from the front will have loosened some of the clips which will almost certainly cause the switch to rattle, creak AND vibrate.
Just teasing!
Who would have thought that those four little switches would generate so much discussion?
sheff
Posts: 1795 Joined: Thu Sep 25, 2014 8:52 am
Post
by sheff » Tue Mar 24, 2015 7:47 pm
andyd wrote: peers.dupp wrote: Hi All,
Resolved!
Although I notice I now need to touch up some paint on the ashtray.
Thanks everyone for your comments.
Glad you got this sorted for Beaulieu, imagine the Embarrasment
Just checked mine and they match yours
I don't think I've seen many Ashtrays that aren't missing some paint
Mine included
Had to check the Cassette was working today....all good
Now to dig out some Tapes
Switches checked......... Tick
Ashtray scratched......... Tick
Wheel numbers match.... Tick
I'm ready for Beaulieu
Hang on, why do my wheels all say 89 on them
Perhaps I might have to cancel
