valve clearances
ThatGuy
Car(s): 1986 2.0 laser
valve clearances
Post by ThatGuy »
I've been rebuilding my carb over the last few day and finally got running nicely and have good throttle response.
While I had the carb off I thought "oh why not do the valve clearances while the carbs off"
They've been sounding shit ever since I've had the car and tried doing them plenty of times to try make them quieter.
And I can finally say, I fucking hate them. Every time I try and gap them right I think they'll sound better and that I'm sorting them. Ofcorse not and now there louder than ever.
Anyone want to come over and sort them for me?
Rant over :)
Ratty as fuck
c.turff
Car(s): Ford capri mk3 1,6 laser. Daily driver ( LPG converted )
Re: valve clearances
Post by c.turff »
Silly qurstion but are you using the right feeler guages? I did mine and got the imperial confused with the metric. Sounded like a tractor
rich_jc
Post by rich_jc »
Make sure the engine is stone cold when you do them. Are you sure you are not confusing the exhaust valves with the inlet ones?
Rich
ThatGuy
Post by ThatGuy »
To be honest what bothouse you have said could be a possibility, I can easily make mistakes like that :p
What side would be classed as what? Say the side with the lock nuts nearest to the inlet, are they the inlet ones? or would it be the side with the spring nearest the inlet be the inlet side?
Either way I was doing it stone cold and usually it helps a little but this time It didnt at all
Any input is greatly appreciated guys
Ratty as fuck
Post by stevemarl »
From the front it`s: Ex, In, Ex, In, Ex, In, Ex, In,
so thats .25, .20, .25, .20 ..... etc etc etc
ThatGuy
Post by ThatGuy »
Cheers for that stevemarl appreciate it I'll give it another go this weekend and hopefully resolve the problem :)
Ratty as fuck
dan the capri fan
Car(s): Black 1986 Ford Capri 1.6 Laser.
Silver 2002 Ford Mondeo 1.8 Zetec, daily driver.
Post by dan the capri fan »
dont get me started on fu**ing tappets im doing mine a 4th time this weekend because i got it wrong the last 3 attempts i either set them too open or too closed. hopefully ill do it as im 100% on what to do :)
ThatGuy
Post by ThatGuy »
dan the capri fan wrote:dont get me started on fu**ing tappets im doing mine a 4th time this weekend because i got it wrong the last 3 attempts i either set them too open or too closed. hopefully ill do it as im 100% on what to do :)
The think is I have been 100% on what to do before and still got it miles out. I'm gunna try again thus weekend but I wouldn't be surprised If it still goes wrong like the other 400 times I've tried to do it
Ratty as fuck
I need to recheck mine actually.. broom broooooom..
Post by stevemarl »
ThatGuy wrote:The think is I have been 100% on what to do before and still got it miles out
Not being funny, but you are making sure you`ve got the cam pointing upwards when you set the gap? And thee feeler goes between the cam and the pad on the follower, not the valve end? It`s hard to imagine what you`re doing wrong. The cam lobes aren`t worn or anthing are they?
Also, you`re not mixing metric/imperial units? Sorry if I sound patronising.
ThatGuy
Post by ThatGuy »
Nah by all means Stevemarl, each time I've done it the cam has been at the top, I've been using the right feeler gauges and I Measure it on when the cam makes contact with thepad underneath it. but every time I fire the engine after its just really loud and tappety. From what I remember the cam didn't look worn when I last did it, but it is a possibility. I'll doubt check everthink next time I do it and if the cam is worn it just means it's for a new cam kit :)
But once again cheers for everything
Ratty as fuck
Matty2148
Car(s): Mk1 GLX
Post by Matty2148 »
You know when you retighten the locknuts, you do recheck the clearances? I`ve fallen for that once, then again when I did it, the engine was super quiet and cut out when the engine reached 3k rpm.
ThatGuy
Post by ThatGuy »
Matty2148 wrote:You know when you retighten the locknuts, you do recheck the clearances? I`ve fallen for that once, then again when I did it, the engine was super quiet and cut out when the engine reached 3k rpm.
Yes I do to make sure they haven't changed while I've tightened them up.
Well I'm giving it another go today so we'll see how it goes
Ratty as fuck
ThatGuy
Post by ThatGuy »
Spent 4 hours today regapping my valves, and it's safe to say.....
MY ENGINE NOW RUNS LIKE A FUCKING CHAMP!!!
Very happy with myself now :)
Ratty as fuck
340truck
Car(s): Rat - GONE
Post by 340truck »
4 hours? Glyn can change an engine in that time. In a field. Twice!
ThatGuy
Post by ThatGuy »
4 hours may have been an exaggeration, but either way I was taking my time just to make sure I'd done each one properly as I didn't really want to do it all over again
Ratty as fuck
