already built it up and cant wait to get it installed!
ive just gota make up the vr sensor bracket, fit a trigger wheel and run the wires around the engine bay and mount the coil on the dizzy (ala Colin stylee!) (oh yet ive yet to connect it to the laptop, but i cant do that till i get me seriel cable)
soon itl be up and running!
Megajolt arrived today!
Re: Megajolt arrived today!
nice one Nat... did you see my post about labels n "normal" forum?
Are you enabling the switchable dual maps?
A Capri is for life... NOT just for Christmas
yes id did see your post..
dont have your address though! i can see the point of the switchable maps, but im not sure if im going to use them, as im not sure what id use it for.
i guess a power/ ragging the snot out of it map, and then one for the motorway or something? i think the switchable maps would be more useful for fueling & ignition combined, rather than just ignition?
what do you think?
what do you think?
i was gona have just that
thou i was thinking identical maps and a lower rev limt in one, say 4500, then another higher up for play time???FUN IS NOT A STRAGHT LINE
Re: i was gona have just that
Switchable maps for me is the difference between 97 and 95RON fuel... I can run with slightly more advance on 97 and it'll be great to be able to switch to another more suitable map for 95RON.
colin
just out of interest, does the megajolt give any power gain? what size cable should i use for a loom? the lecy guys wont give me any cable untill i know what size cable or the current of the set up, cheers martynFUN IS NOT A STRAGHT LINE
now theres an idea!
switchable for fuel octane ratings... very good idea there!
actually thats bloody brilliant, i think il be trying that one out. is it difficult to do?, i mean loading two maps upto the mjl? ive not tried connecting mine to the laptop yet as my connector lead hasnt arrived yet.
i guess it would be good for tuning to, swapping between two different maps and seeing which ones the best? i guess i could have one blank/ std map and the one im working on. then when i go to a R&R they could map the blank one and i could compare the to on the road instantly..
food for thought i guess.
current is probably less than an amp
length, only one to find out, you need to position everything in the engine bay and the cabin, then figure roughly how long it all wants to be.
Re: now theres an idea!
yup... that's exactly what it's for. My 2.1 hates 95RON fuel... I've had to retard it all over the map... with 97 I can advance it back up, so being able to switch between the 2 is great. Also, as you say, you could have a "safe" map and a "development" map... or one setup for economy...
Programming the 2 maps is easy... simply throw the switch and upload... depending on the switch position, you'll have access to one or other of the maps... you can't access both together, which is a nice safety thing I guess.
