Can the 'serial to usb' adapter/lead be connected to the mjl unit while driving the car? ie leaving the lead in place but not having the laptop connected.
will it be ok or will the chip in the conversion lead confuse the mjl if its left connected to the mjl while the laptop isnt connected?
does that make sense?
any thoughts id be greatful.
Colin, got a mjl q for you....
- Beakster
Re: Colin, got a mjl q for you....
Yo,
Although I'm not Colin I'm gonna say it will be fine.
RS232 doesn't have a concept of state. It just streams bits in both directions at a speed determined by clients at both ends. Therefore if the MJ isn't receiving any data, which it won't be without a computer, it won't even know there is anything plugged in.
Also the USB to Serial controller chip gets its power from the USB bus, and without a USB controller in a computer to power it, it will be completely inactive.
-Chris
-Chris
ah that clears things up!
i wasnt sure if if the chip would get power from the serial end?
(can you tell how much i know about computery things?)
thanks mate!
thanks mate!
Re: ah that clears things up!
aye... just what Beakster said
A Capri is for life... NOT just for Christmas
