Et voila!!!
Et voila!!!
one modded dizzy for edis, same style as Colins... dizzy arrived at 11.00 this morning, i had an hours lunch and spent at least an hour huffing boxes about for the old dear....
looking good
whens the trigger whell coming? thats ur last bit aint it?
FUN IS NOT A STRAGHT LINE
Re: Et voila!!!
I notice you have mounted the coil pack centrally... will it clear the inlet manifold? I wasn't too sure whether it would with the leads on, so I offset mine just incase...
A Capri is for life... NOT just for Christmas
i did think about this
and from what i can see, it looks like it will be ok, but i ahvent tried it in place of the original yet! fingers crossed lol!
and yep, trigger wheel and serial/usb cable are the last bits. gota make up the sensor mount too, heavy gauge angle iron me thinks?
Re: Et voila!!!
in fact, I was most concerned that it would have enough clearance for he cam belt... tried to keep as much distance between the coil and belt as possible as I run without a cover:
Re: Et voila!!!
I think that I have about 12mm of clearance between the coil pack mounting plate and the belt... centralising the coil pack would have brought it far too close for me.
this is the problem i had
with the bike carbs i have clearence issuse with the standard dissy cap, and as i also have no blet cover i didnt want to risk catching on either the carbs or the cam beltFUN IS NOT A STRAGHT LINE
- Beakster
Re: Et voila!!!
That was quick! You're gonna be done in no time!
I'm on the look out for a dizzy to mod if anyone has a spare one for sale.
I reckon I'm going to struggle with getting the the dizzy and VR sensor brackets made up.
ive had a closer look
and im happy with the clearance, dont think the cam belt will be an issue, the inlet will be close, but should be ok...
cant do the vr sensor untill i get the trigger wheel tho..
its all goooood
its all goooood
Re: ive had a closer look
which trigger wheel are you using? I noticed you're getting through GooRoo... if it's the Sierra CVH one, then the price Chris quoted is less than some scrappies want for used ones... I ended up paying £17.50 for my first one... got a second put aside for the TT, which may well get the MJLJ treatment too.
- Beakster
Help
Ok I'm really not sure where to start in terms of buying the nuts and bolts.
What am I going to need to get to mod the dizzy and fit the VR sensor?
I see in Colin's pic of the inside of the dizzy he has screwed 4 things in which the bolts holding the Coil Pack bracket screw into. What are these bolt socket things? Where can I get them and what sizes do I need? Also how to I attach them to the dizzy? Do I need to drill holes then tap a thread? Can I do it with a normal drill or do I need to buy a bench drill?
And what type and size of bolts do I need?
Any advice much appreciated as I don't have a clue about this bit.
-Chris
-Chris
Re: Help
the pillars are ones used in electronics and have an M4 stud on one end... the 4 holes are already there in the dizzy... I just tapped them to suit and put a locking nut on for security. the larger pillars to hold the coil are tapped M5 at one end and have an M5 stud the other end.
I may be able to supply you with suitable pillars... I'll have to have a scout round.
i guess its that one,
was only aware of one? he hasnt got back to me yet, so might have to get one off ebay yet, dont really want to though, 25 quid !
Quite a transformation
from the dizzy I put in the post! Glad it was OK just wish I understood what you, Colin et al are doing but never mind.
lol come to mini COCC and you can learn all about it!
money in the post mate, thanks very much!
of course! infact you have to go!
speak to Glyn hes got the details, its only a fiver too! if you cant get hold of him, i can reach him on osf forum..
You guys amaze meyou really do.
With all you knowledge and ingenuety. I just bunged a lumenition on mine where as you lot go all out and build something ford engineers struggled with for ages. My hat is off to you.
i just hope its worth all the effort!
im sure it will be!
Re: i just hope its worth all the effort!
certainly was worth it with my 2.1
Paid for itself in 1 year in saved fuel alone, and I do less than 3000 miles...
