Pinto Power
Beakster
Pinto Power
Post by Beakster »
Came across this today so thought I'd post it up for your viewing pleasure :)
Supercharged Nat
cool
Post by Supercharged Nat »
interesting reading!Image
Matty28i
Car(s): Mk3 2.8i not a 2.8i any more... 2.9 24V BOB Long Term Project.
Re: Pinto Power
Post by Matty28i »
Thanks Chris for that down draft carb shot.
I've not seen any fitted yet, but it is the set up that the Mk2 will have if I ever get it running again.
The manifold I have is original Ford and will take huge carbs or fuel injetcion.
Looks like plenty of bonnet clearance space as well for some trumpets.
Matty28i
Beakster
Couple of things about that article
Post by Beakster »
1) They say that injection head flows better, but I've heard the notching means its not as good?
2) In the top left hand corner it mentions using 2 spark plugs per cylinder but doesn't elaborate on it. Any one ever heard of this on a Pinto?Image
aerosam
ok....
Post by aerosam »
1) Injection head flows better as the ports are better internally. On the other hand, the injector nicks can cause leakage problems when fitting a carb manifold on an injection head.
2) My guess would be they are referring to the picture in the corner next to the comment. There appears to be 8 spark plugs lined up above the valves. Can't really see any detail on the head, perhaps a higher quality scan of just that area would reveal more.Efi Pinto's rock!!!
Terra-Kotta
Car(s): Pinto/crossflow guru.
CCC twin spark pinto article.......
Post by Terra-Kotta »
Was waaaaaaay back in 1989-90 i think, i remember seeing it, it made a couple of extra BHP but the whole idea of it was to run more lumpy cams on the street which it did score very well on, apparently it idled loads better due to a more controlled burn.
if your into REAL performance cars then CCC is and allways has been the mag to get.
