megajolt update and a question
thesnake505
Post by thesnake505 »
quick update, i got the edis module and the coil pack wired in today, just need to wire the mj unit up and is done, and i have to say the sheilded cablbe thing i really struggled to get a wire attatched to the braid! is it wrong to assume the colours on the edis and the pick up sensor should match up? the clours are the same however im not sure how to tell which is postive, so i asssume the wires just match up to the edis ones!!
cheers snakeFUN IS NOT A STRAGHT LINE
Supercharged Nat
eh?
Post by Supercharged Nat »
the vr sensor wires should match the ones on the edis modual. eg, black with green stripe would match to the one on the edis with a black wire and green stripe!
does that answer your question?
thesnake505
yea it does except
mine are green with yello and green with blue lol, sorry for confusing post lol, in simple words all i need to do iswire in the mj, and mount the trigger wheen and sensor
Supercharged Nat
cool im currently working on the brakes and suspension
and the tracking but once ive got that done, im guna mount me trigger wheel and install the mjl wires/ edis modual. should be up and running within a day.
might not be able to get it done this weekend, but hopefully next.Image
