Yo,
Went for an MOT this morning, and it passed Never had a car pass first time until now.
Only problem they found was one of the headlight bulbs. I never bothered to check them cos I wasn't expecting a pass so really just wanted a list of things to fix for the free retest.
Guy says he could fit a new bulb there and then and pass it, so I said ok. 15 mins later he still wasnt back so I went to see what he was doing. Found him with the bezel and headlight assembly on the floor, so I showed him the little plastic cover you can remove to get access to the bulbs. lol
Only thing they flagged up that I wasn't sure about was "movement in N/S hub assembly". Is that wheel bearing related?
-Chris
Todays MOT Test
could be
could also be a worn tca bush or tie rod, but thought they would be a little more detailed than that.
simple to check for wheel bearing though. jack it up off the ground take hold of tyre top and bottom (not side to side) and then rock up and down. if theres any play with will feel a slight knock as you go from top to bottom.
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
But, be aware....
A small amount of lift is OK. If the bearings are over tight they'll wear very quickly. Sorry to be a pedant LOL.
