Sorry, t'other thread was getting too long for my liking.
So Tom/Glyn, what is the spec of that engine then? Id love to get to 130bhp when mine is eventually going.
Rich
New Major Tom engine thread...
I think it's
almost same spec as mine i.e. Std bottem end, FR32 Kent cam, 4 branch & Twin choke. Only difference is mine has leccy ignition, injection head (Better flow) & a 38 DGAS jetted to suit.
- rich_jc
Cool, there's hope for me then...
When you say "built an engine", I imagine new rods and crank, etc...
Mine is a standard 2.0 with a 4 branch and 32/36, standard cam. Id like to get a fast road cam, do a bit of diy porting, keep the 32/36 and get it set up properly as per.
Oh, and ive got the leccy igntion and a kenlowe (if you believe that a leccy fan gives you more power).
Rich
Rich
Re: Leccy fan
must be famous, it's on capri power too now!
http://www.capripower.co.uk/bboard/view ... f=3&t=5670JC|2 LITRE LASER AUTOMATIC|STRATOS SILVER
also ensure a vernier pulley is used
(on the cam) the bottom end doesnt need to be new, just in good nick! if the motors done 100,000 then itl benefit froma freshen up- new bearing (crank and big and end) and new piston rings- possibly a rebore and new pistons too (depends on how worn the bores are)
thats pretty much my spec except ive got the supercharger bolted to it too (and a full 2.5" exhaust system & megajolt). it made 146 on the first run. now its time to tune the carb properly and make the most of the ecu.
if you go 2.1, 38dgas, stage 3 head you could see nearly 160bhp.
bigger carbs 40's/45's even more...
